* | score: Create thread implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+1 |
| | | | | | | | | Move implementation specific parts of thread.h and thread.inl into new header file threadimpl.h. The thread.h contains now only the application visible API. Remove superfluous header file includes from various files. | ||||
* | score: Create schedulerpriority impl header | Sebastian Huber | 2013-07-26 | 1 | -4/+2 |
| | | | | | | | | | | | | | Move implementation specific parts of schedulerpriority.h and schedulerpriority.inl into new header file schedulerpriorityimpl.h. The schedulerpriority.h contains now only the application visible API. Add missing includes. Remove superfluous includes. Move declaration of _Priority_Bit_map to prioritybitmap.inl since this variable is used only here. Remove second declaration of _Priority_Major_bit_map. | ||||
* | Score misc: Clean up Doxygen #4 (GCI 2012) | Alexandre Devienne | 2012-11-28 | 1 | -0/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7985215 | ||||
* | 2011-10-04 Sebastian Huber <sebastian.huber@embedded-brains.de> | Jennifer Averett | 2011-10-04 | 1 | -0/+2 |
| | | | | | | PR 1922 * score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c: EDF and CBS scheduler: extern declarations fix. | ||||
* | 2011-09-15 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-15 | 1 | -0/+59 |
PR 1906/cpukit * sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add the CBS (Constant Bandwidth Server) scheduler. This is a complex scheduling policy built atop of the EDF scheduler. Unlike other schedulers, this one provides a user API and handles not only deadlines of tasks but also claimed budget per period. The main aim of the scheduler is isolation of tasks so that each task is guaranteed to meet all deadlines regardless of how other tasks behave. * sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl, score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c, score/src/schedulercbsattachthread.c, score/src/schedulercbscleanup.c, score/src/schedulercbscreateserver.c, score/src/schedulercbsdestroyserver.c, score/src/schedulercbsdetachthread.c, score/src/schedulercbsgetapprovedbudget.c, score/src/schedulercbsgetexecutiontime.c, score/src/schedulercbsgetparameters.c, score/src/schedulercbsgetremainingbudget.c, score/src/schedulercbsgetserverid.c, score/src/schedulercbsreleasejob.c, score/src/schedulercbssetparameters.c, score/src/schedulercbsunblock.c: New files. |
