path: root/cpukit/score/src/scheduler.c (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Use scheduler instance specific locksSebastian Huber2016-11-021-4/+12
| | | | Update #2556.
* score: Add scheduler acquire/releaseSebastian Huber2015-03-241-0/+2
| | | | | | | This is currently a global lock for all scheduler instances. It should get replaced with one lock per scheduler instance in the future. Update #2273.
* score: Static scheduler configurationSebastian Huber2014-04-151-1/+8
| | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
* score: Create scheduler implementation headerSebastian Huber2013-07-261-3/+1
| | | | | | Move implementation specific parts of scheduler.h and scheduler.inl into new header file schedulerimpl.h. The scheduler.h contains now only the application visible API.
* Score misc: Clean up Doxygen #8 (GCI 2012)Mathew Kallada2012-11-291-2/+7
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7970221
* 2011-02-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-181-17/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/thread.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/scheduler.c, score/src/schedulerpriority.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadsetpriority.c, score/src/threadsettransient.c: Significant clean up on Scheduler Plugin Interface. Names were shortened. Missing operations added. Many scheduler files had unneeded includes removed. Made pointer to scheduler information in Thread_Control and Scheduler_Control a void * pointer because the thread and scheduler wrapper should be unaware of scheduler types AND this is broken for user provided schedulers. * score/src/schedulerpriorityallocate.c, score/src/schedulerpriorityenqueue.c, score/src/schedulerpriorityenqueuefirst.c, score/src/schedulerpriorityextract.c, score/src/schedulerpriorityfree.c, score/src/schedulerpriorityupdate.c: New files. * score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* 2011-02-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-171-9/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | * sapi/include/confdefs.h, sapi/include/rtems/config.h, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/scheduler.c, score/src/schedulerpriority.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadready.c, score/src/threadresume.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the pluggable scheduler interface. Its configuration made a table of available schedulers and set a pointer to one of the. This was heavy handed since you can only use one scheduler in an application. This configuration mechanism resulted in a scheduler pointer being passed around when you could put all scheduler configuration in an initialized structure.
* 2010-11-24 Gedare Bloom <giddyup44@yahoo.com>Joel Sherrill2010-11-241-0/+45
PR 1647/cpukit * posix/src/nanosleep.c, posix/src/sched_yield.c, rtems/src/taskwakeafter.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/prioritybitmap.h, score/include/rtems/score/thread.h, score/inline/rtems/score/thread.inl, score/src/thread.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadready.c, score/src/threadresume.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsettransient.c, score/src/threadsuspend.c, score/src/threadtickletimeslice.c: Refactor scheduler out of thread handler to facilitate alternate scheduler implementations. * score/src/threadyieldprocessor.c: Removed. * score/src/schedulerprioritythreadschedulerupdate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerpriorityblock.c, score/src/scheduler.c, score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/scheduler.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl: New files.
