* | Add and use RTEMS_CONTAINER_OF() | Sebastian Huber | 2014-08-05 | 1 | -4/+2 |
* | score: Add Resource Handler | Sebastian Huber | 2014-06-03 | 1 | -0/+106 |
A resource is something that has at most one owner at a time and may have multiple rivals in case an owner is present. The owner and rivals are impersonated via resource nodes. A resource is represented via the resource control structure. The resource controls and nodes are organized as trees. It is possible to detect deadlocks via such a resource tree. The _Resource_Iterate() function can be used to iterate through such a resource tree starting at a top node. |
