2015-08-31 | rbheap: Drop direction from _RBTree_Iterate() | Sebastian Huber | 1 | -5/+3 | |
2014-07-22 | rbtree: Format | Sebastian Huber | 1 | -6/+6 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2013-11-21 | score/rbtree: Remove "unprotected" from API | Sebastian Huber | 1 | -3/+3 | |
2013-07-23 | score: Create rbtree implementation header | Sebastian Huber | 1 | -1/+1 | |
Move implementation specific parts of rbtree.h and rbtree.inl into new header file rbtreeimpl.h. The rbtree.h contains now only the application visible API. | |||||
2012-05-08 | rbtree: API changes. Remove rbtree control node from RBTree_Next. | Gedare Bloom | 1 | -1/+1 | |
The implementation of RBTree_Next was using an awkward construction to detect and avoid accessing the false root of the red-black tree. To deal with the false root, RBTree_Next was comparing node parents with the control node. Instead the false root can be detected by checking if the grandparent of a node exists; the grandparent of the tree's true root is NULL by definition so the root of the tree is found while walking up the tree by checking for the non-existence of a grandparent. This change propagates into the predecessor/successor and iterate functions. | |||||
2012-04-11 | rbtree: New function _RBTree_Iterate_unprotected() | Sebastian Huber | 1 | -0/+45 | |
