Save the return value from the unprotected version and return it after
enabling interrupts to their previous level.
When inserting to a red-black tree with duplicates the min and max pointers are
not updated properly. We need to check the key of the min/max node against the
insert node since the insert point could be the child of a node with an
identical key to the min/max node.
Change the meaning of the compare result to simplify comparison of
integer keys.
* score/src/rbtreeextract.c:
Make _RBTree_Extract_validate_unprotected static.
* score/src/rbtreeinsert.c:
Make _RBTree_Validate_insert_unprotected static.
PR 1886/cpukit
* sapi/include/rtems/rbtree.h, sapi/inline/rtems/rbtree.inl,
score/include/rtems/score/rbtree.h,
score/inline/rtems/score/rbtree.inl, score/src/rbtree.c,
score/src/rbtreeinsert.c: This patch enables inserting duplicate keys
into rbtree. It is possible to turn on this feature when initializing
the tree.
PR 1877/cpukit
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/memfile.c,
sapi/inline/rtems/rbtree.inl, score/include/rtems/score/rbtree.h,
score/src/rbtreefind.c, score/src/rbtreeinsert.c: Add comparison
function for RBTrees.
PR 1641/cpukit
* sapi/Makefile.am, sapi/preinstall.am, score/Makefile.am,
score/preinstall.am: Add Red Black Tree data structure to score.
score/include/rtems/score/rbtree.h, score/inline/rtems/score/rbtree.inl,
score/src/rbtree.c, score/src/rbtreeextract.c,
score/src/rbtreefind.c, score/src/rbtreefindheader.c,
score/src/rbtreeget.c, score/src/rbtreeinsert.c,
score/src/rbtreepeek.c: New files.
