Use the BSD <sys/tree.h> implementation since it is faster, more
flexible and uses less storage. See https://github.com/sebhub/rb-bench.
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
The user of the red-black tree container must now ensure that at most
one thread at once can access an instance.
Move implementation specific parts of rbtree.h and rbtree.inl into new
header file rbtreeimpl.h. The rbtree.h contains now only the
application visible API.
This function is to big to inline. It leads also to test case
explosion.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
PR 1877/cpukit
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/memfile.c,
sapi/inline/rtems/rbtree.inl, score/include/rtems/score/rbtree.h,
score/inline/rtems/score/rbtree.inl, score/src/rbtree.c,
score/src/rbtreefind.c, score/src/rbtreeinsert.c: Add comparison
function for RBTrees.
PR 1641/cpukit
* sapi/Makefile.am, sapi/preinstall.am, score/Makefile.am,
score/preinstall.am: Add Red Black Tree data structure to score.
* sapi/include/rtems/rbtree.h, sapi/inline/rtems/rbtree.inl,
score/include/rtems/score/rbtree.h, score/inline/rtems/score/rbtree.inl,
score/src/rbtree.c, score/src/rbtreeextract.c,
score/src/rbtreefind.c, score/src/rbtreefindheader.c,
score/src/rbtreeget.c, score/src/rbtreeinsert.c,
score/src/rbtreepeek.c: New files.
