The user of the red-black tree container must now ensure that at most
one thread at once can access an instance.
Move implementation specific parts of rbtree.h and rbtree.inl into new
header file rbtreeimpl.h. The rbtree.h contains now only the
application visible API.
The implementation of RBTree_Next was using an awkward construction to detect
and avoid accessing the false root of the red-black tree. To deal with the
false root, RBTree_Next was comparing node parents with the control node.
Instead the false root can be detected by checking if the grandparent of a
node exists; the grandparent of the tree's true root is NULL by definition
so the root of the tree is found while walking up the tree by checking for
the non-existence of a grandparent.
This change propagates into the predecessor/successor and iterate functions.
During node extraction from a red-black tree the min and max values are updated
incorrectly. We need to use the successor/predecessor functions to find the
next/previous node when we remove the min/max from the tree.
Add a red-black tree helper method to ease obtaining the direction opposite
to the current direction. Useful for manipulating and traversing an rbtree.
* score/src/rbtreeextract.c:
Make _RBTree_Extract_validate_unprotected static.
* score/src/rbtreeinsert.c:
Make _RBTree_Validate_insert_unprotected static.
PR 1861/cpukit
* score/src/rbtreeextract.c: Remove redundant code.
PR 1856/cpukit
* posix/src/pthread.c, posix/src/pthreadjoin.c,
score/src/rbtreeextract.c: Do not derefence NULL.
PR 1641/cpukit
* sapi/Makefile.am, sapi/preinstall.am, score/Makefile.am,
score/preinstall.am: Add Red Black Tree data structure to score.
* sapi/include/rtems/rbtree.h, sapi/inline/rtems/rbtree.inl,
score/include/rtems/score/rbtree.h, score/inline/rtems/score/rbtree.inl,
score/src/rbtree.c, score/src/rbtreeextract.c,
score/src/rbtreefind.c, score/src/rbtreefindheader.c,
score/src/rbtreeget.c, score/src/rbtreeinsert.c,
score/src/rbtreepeek.c: New files.
