* | score: Add per-CPU profiling | Sebastian Huber | 2014-03-14 | 1 | -0/+45 |
Add per-CPU profiling stats API. Implement the thread dispatch disable level profiling. The interrupt profiling must be implemented in CPU port specific parts (mostly assembler code). Add a support function _Profiling_Outer_most_interrupt_entry_and_exit() for this purpose. |
