* | 2011-12-06 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-12-06 | 1 | -0/+40 |
* score/src/heapiterate.c, score/src/pheapiterate.c: New files. * score/Makefile.am: Reflect changes above. * score/include/rtems/score/heap.h: Declare _Heap_Iterate() and define Heap_Block_visitor. * score/include/rtems/score/protectedheap.h: Declare _Protected_heap_Iterate(). * score/src/heapgetinfo.c: Use _Heap_Iterate(). |
