path: root/cpukit/score/src/pheapgetblocksize.c (follow)
* 2009-09-06 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-09-061-2/+10
| | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/free.c, libmisc/stackchk/check.c, rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapgetsize.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: Update for heap API changes. * score/include/rtems/score/apimutex.h, score/include/rtems/score/object.h: Documentation. * score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/inline/rtems/score/heap.inl, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/heapwalk.c: Overall cleanup. Added boundary constraint to allocation function. More changes follow.
* 2009-08-24 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-08-261-1/+1
| | | | | | | | | | | | | * libmisc/stackchk/check.c, rtems/src/regionreturnsegment.c, rtems/src/regiongetsegmentsize.c, src/heapalignupuptr.c, src/heapallocatealigned.c, src/heapallocate.c, src/heap.c, src/heapextend.c, src/heapfree.c, src/heapgetfreeinfo.c, src/heapgetinfo.c, src/heapresizeblock.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/pheapgetblocksize.c, inline/rtems/score/heap.inl, include/rtems/score/heap.h: Overall cleanup. Changed all types for addresses, sizes, offsets and alignments to uintptr_t. Reformatted. Added variables for clarity. Renamed various objects. Enabled _HAssert() for all instances. More changes follow.
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-141-1/+1
| | | | | | | | | | | | | | | | * libcsupport/src/realloc.c, rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionmp.c, rtems/src/regionresizesegment.c, sapi/include/rtems/config.h, score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapgetblocksize.c, score/src/pheapresizeblock.c: Change sizes of heap/region and allocated objects in heap to intptr_t so they can be larger than a single allocatable object (e.g. size_t).
* 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-201-1/+1
| | | | | | | | | | | | | | * score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/include/rtems/score/wkspace.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c, score/src/wkspace.c: Revert use of ssize_t. This type is not guaranteed to be able to represent a positive number greater than the size of a single allocatable object. We needed a type that is able to represent the size of a pool of multiple allocatable objects or potentially nearly all memory.
* 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-021-1/+1
| | | | | | | | | | | | | | | | | * libcsupport/src/malloc_statistics_helpers.c, libcsupport/src/realloc.c, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/support.h, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, rtems/src/workspace.c, sapi/include/confdefs.h, score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/include/rtems/score/wkspace.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c, score/src/wkspace.c: Change size_t to ssize_t on all Heap, Workspace and Region calls. On 16-bit architectures, size_t can be 16-bits which would limit sizes to 64K.
* Convert to "bool".Ralf Corsepius2008-09-041-2/+2
* 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-111-8/+7
| | | | | * score/src/pheapallocatealigned.c, score/src/pheapgetblocksize.c: Reverse file contents.
* 2007-05-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-05-031-0/+32
* ChangeLog, libcsupport/src/malloc.c, libcsupport/src/mallocfreespace.c, sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: malloc never blocks so the Region Manager is quite heavy for implementing this. This patch implements the C Program Heap directly in terms of the new Protected Heap handler. This handler is a direct use of a SuperCore Heap in conjunction with the Allocator Mutex used internally by RTEMS. This saves 3184 bytes on most SPARC test executables. * score/include/rtems/score/protectedheap.h, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: New files.
