path: root/cpukit/score/src/pheapfree.c (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* Remove superfluous <rtems/system.h> includesSebastian Huber2019-03-141-1/+0
* 2009-09-06 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-09-061-0/+8
| | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/free.c, libmisc/stackchk/check.c, rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapgetsize.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: Update for heap API changes. * score/include/rtems/score/apimutex.h, score/include/rtems/score/object.h: Documentation. * score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/inline/rtems/score/heap.inl, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/heapwalk.c: Overall cleanup. Added boundary constraint to allocation function. More changes follow.
* Convert to "bool".Ralf Corsepius2008-09-041-2/+2
* 2007-05-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-05-031-0/+30
* ChangeLog, libcsupport/src/malloc.c, libcsupport/src/mallocfreespace.c, sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: malloc never blocks so the Region Manager is quite heavy for implementing this. This patch implements the C Program Heap directly in terms of the new Protected Heap handler. This handler is a direct use of a SuperCore Heap in conjunction with the Allocator Mutex used internally by RTEMS. This saves 3184 bytes on most SPARC test executables. * score/include/rtems/score/protectedheap.h, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: New files.
