* score/src/objectnametoid.c, score/src/objectnametoidstring.c:
Remove useless variable pointed out by clang.
* score/src/threadstackallocate.c: Remove useless variable
initialization pointed out by clang.
* sapi/include/confdefs.h, score/src/mpci.c, score/src/objectmp.c,
Multiprocessing compiles again and survives initialization. The
recent object name and confdefs.h changes had broken it.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* score/inline/rtems/score/object.inl, score/src/objectnametoid.c:
Properly honor searching only local node even when on single CPU
system.
* score/src/coresemsurrender.c, score/src/objectnametoid.c: All
_Objects_Is_Local... should only be called if multiprocessing is
enabled.
PR 618/rtems
* rtems/include/rtems/rtems/status.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/dpmemcreate.c,
rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c,
rtems/src/eventreceive.c, rtems/src/eventsend.c,
rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c,
rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c,
rtems/src/partcreate.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/regioncreate.c,
rtems/src/regiondelete.c, rtems/src/regionextend.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionreturnsegment.c, rtems/src/semcreate.c,
rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c,
rtems/src/taskcreate.c, rtems/src/taskgetnote.c,
rtems/src/taskmode.c, rtems/src/taskrestart.c,
rtems/src/taskresume.c, rtems/src/tasksetnote.c,
rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c,
rtems/src/taskwakewhen.c, rtems/src/timercreate.c,
rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c,
rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h,
score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL
checks.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
* Makefile.am, include/rtems/score/object.h,
include/rtems/score/objectmp.h, src/objectmp.c, src/objectnametoid.c:
Added ID to name lookup service and changed name of id/name
translation status code. This propagated to multiple functions. The
user API service added was rtems_object_id_to_name()
* src/objectidtoname.c: New file.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/Makefile.am, include/rtems/score/coremsg.h,
include/rtems/score/coremutex.h, include/rtems/score/coresem.h,
include/rtems/score/object.h, include/rtems/score/threadq.h,
inline/rtems/score/object.inl, inline/rtems/score/thread.inl,
macros/rtems/score/object.inl, src/Makefile.am, src/coremsg.c,
src/coremutex.c, src/coresem.c, src/mpci.c,
src/objectcomparenameraw.c, src/objectextendinformation.c,
src/objectinitializeinformation.c, src/objectnametoid.c,
src/thread.c, src/threadclose.c, src/threadget.c, src/threadq.c,
src/threadqextractwithproxy.c: Modified as part of above.
* include/rtems/score/apimutex.h, src/objectgetnoprotection.c: New
files.
