Remove the superfluous invalid name check since the object creation
directives ensure that objects with such a name cannot exist. Also
finding an object with such a name would be no catastrophy if it really
exists.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3735.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Update #3706
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Use a red-black tree to lookup active global objects by identifier or
name.
Update #2555.
Bug introduced by be8897644043e4378db7add02c3c9e1ac7fde563.
Update #2555.
The object creation/deletion is protected by the object allocator lock.
Update #2555.
Delete SCORE_INIT. This finally removes the
some.h:
#ifndef SOME_XYZ_EXTERN
#define SOME_XYZ_EXTERN extern
#endif
SOME_XYZ_EXTERN type xyz;
some_xyz.c:
#include <some.h>
pattern in favour of
some.h:
extern type xyz;
some_xyz.c
#include <some.h>
type xyz;
Update #2559.
Rename _Internal_error_Occurred() into _Terminate().
application visible API.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
* libblock/src/show_bdbuf.c, score/src/objectmp.c: Avoid chain API
violations.
* sapi/src/exinit.c, score/include/rtems/score/objectmp.h,
score/src/objectmp.c: Ensure local node number is set early enough in
MP configurations.
* rtems/include/rtems/rtems/regionmp.h, sapi/include/rtems/config.h,
sapi/src/exinit.c, score/Makefile.am,
score/include/rtems/score/objectmp.h, score/src/objectmp.c: Eliminate
Object Handler Initialization routine since it was all for MP
configurations.
* score/src/object.c: Removed.
* sapi/include/confdefs.h, score/src/mpci.c, score/src/objectmp.c,
score/src/objectnametoid.c, score/src/objectnametoidstring.c:
Multiprocessing compiles again and survives initialization. The
recent object name and confdefs.h changes had broken it.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
PR 661/rtems
* score/src/objectmp.c: Fix invalid dereference.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
* Makefile.am, include/rtems/score/object.h,
include/rtems/score/objectmp.h, src/objectmp.c, src/objectnametoid.c:
Added ID to name lookup service and changed name of id/name
translation status code. This propagated to multiple functions. The
user API service added was rtems_object_id_to_name()
* src/objectidtoname.c: New file.
* src/objectmp.c: Removed warnings.
* src/objectmp.c: Corrected use of name parameter to reflect that it
is actually the name not a pointer to the name.
like signal dispatching.
correct Information block.
