Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c,
httpd/websuemf.c, libblock/src/diskdevs.c,
libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c,
score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
* score/include/rtems/score/object.h,
score/inline/rtems/score/object.inl,
score/src/objectgetnameasstring.c, score/src/objectidtoname.c,
score/src/objectinitializeinformation.c,
score/src/objectnamespaceremove.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c, score/src/thread.c,
score/src/threadcreateidle.c: Disable object string name support when
POSIX is not enabled.
* rtems/include/rtems/rtems/region.h,
rtems/src/rtemsobjectgetclassinfo.c, score/src/heapwalk.c,
score/src/objectgetnameasstring.c, score/src/objectsetname.c,
score/src/timespecdivide.c, score/src/ts64divide.c: Remove include of
stdio.h
* rtems/src/rtemsobjectsetname.c, score/src/objectgetinfoid.c,
score/src/objectgetnameasstring.c, score/src/objectidtoname.c: Handle
Object Id of SELF.
* posix/src/cond.c, posix/src/key.c, posix/src/mqueuenametoid.c,
posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c,
posix/src/pspin.c, posix/src/pthread.c, posix/src/ptimer.c,
posix/src/semaphorenametoid.c: Add option for all POSIX objects
whether named or unnamed to have a string name. If the API does
not directly support having a name, then the user must explicitly
assign it using rtems_object_set_name().
* rtems/src/rtemsobjectgetapiclassname.c: Improved testability.
score/src/objectgetnameasstring.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c: Modifications required to pass testing of
recently modified object name operations. Also eliminated
multiprocessing related code that was not reachable.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectextendinformation.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
* score/src/objectgetnameasstring.c: Internal threads use string names
so in the current RTEMS source string object name can NOT be
disabled. It is probably worth considering converting the internal
threads to uint32_t style names so all the support for string names
can be conditionally disabled.
* score/src/objectgetnameasstring.c: Remove bogus ifdef
RTEMS_POSIX_API.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
