Update #3706
This information is already present in Objects_Information::maximum_id.
Add and use _Objects_Get_maximum_index().
Update #3621.
application visible API.
PR 1660/filesystem
* libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.h: Changed
int pipe_release to void pipe_release.
* libfs/src/imfs/imfs_fifo.c: Corresponding change to
IMFS_fifo_close since pipe_release does not return any error.
* libfs/src/imfs/imfs_initsupp.c: Changes to improve
IMFS_determine_bytes_per_block
* score/src/objectgetinfo.c: Clean up and eliminate unreachable code.
* rtems/src/rtemsobjectapimaximumclass.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c: Change
return type of API maximum class methods to unsigned.
* score/src/objectgetinfo.c: Correct for multiprocessor systems when
all object instances within a particular class are remote.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
* score/src/objectgetinfo.c, score/src/objectidtoname.c,
score/src/threadget.c: Make sure the pointer to the API object table
is valid before derefencing it.
* score/include/rtems/score/object.h, score/src/objectgetinfo.c,
rtems/include/rtems/rtems/object.h,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetclassinfo.c: class is a C++ keyword and
cannot be used as a parameter.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/objectgetnameasstring.c,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
