* | score: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -2/+5 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Split up objects free | Sebastian Huber | 2020-02-12 | 1 | -0/+47 |
Split up the different objects free methods into separate functions. This helps to avoid a dependency on the workspace in case no objects or a static set of objects is configured. Update #3835. |
