path: root/cpukit/score/src/objectfree.c (follow)
* 2009-10-08 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-081-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am: Added statvfs.h. * libcsupport/Makefile.am: Add statvfs.c. * libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c: New. * libcsupport/include/rtems/libio.h: Add a file system handler for the statvfs call. * libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the statvfs handler to NULL. * include/rtems/fs.h: Add a second node access field for the RFS file system to hold a directory offset while the existing field holds the inode number. This save a rescan of the directory when working with directories. * libblock/include/rtems/bdbuf.h: Added references and user fields to the buffer descriptor. * libblock/src/bdbuf.c: Added dynamic buffer support for different block sizes. Fixed a number of bugs. * libblock/src/blkdev.c: Release the disk device on an error. * libblock/src/diskdevs.c: Set the block size to the media block size during initialisation of the disk device. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk.c: Updated the drivers to handle variable block sizes. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any buffers when an error occurs. The FAT buffer layer hangs onto a single buffer while mounted. This should be fixed. * sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain, rtems_chain_is_node_off_chain, and rtems_chain_previous. * score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain, and _Chain_Is_node_off_chain. * libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c, libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h: New shell commands. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and mknod commands. * libmisc/shell/hexdump-display.c: Fixed the reopen bug which showed up as a free with a bad pointer. * libmisc/shell/main_mount.c: List the user adding file system when listing the available file systems to mount. * libmisc/shell/utils-cp.c: Remove the fixed static copy buffer and use a large dynamic buffer. * score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c, score/src/objectallocate.c, score/src/objectfree.c: Remove warnings.
* Include config.h.Ralf Corsepius2005-01-271-0/+4
* Remove stray white spaces.Ralf Corsepius2004-04-181-1/+1
* Remove stray white spaces.Ralf Corsepius2004-04-171-3/+3
* 2004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-291-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapsizeofuserarea.c, score/src/interr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadget.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstart.c, score/src/userext.c, score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using c99 fixed size types.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
* Split object.c into multiple files.Joel Sherrill1999-11-021-0/+66
