path: root/cpukit/score/src/objectclose.c (follow)
* score misc: Score misc: Clean up Doxygen #7 (GCI 2012)Alex Ivanov2012-11-291-0/+7
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
* 2008-05-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-05-221-5/+1
| | | | | | | | | | | | | * itron/include/rtems/itron/task.h, itron/src/del_tsk.c, itron/src/exd_tsk.c, itron/src/task.c, posix/include/rtems/posix/threadsup.h, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/testcancel.c, rtems/src/taskdelete.c, score/inline/rtems/score/object.inl, score/src/objectclose.c, score/src/threadclose.c: Make all task delete/exit/cancel routines follow the same critical section pattern. Also ensure that POSIX cancelation routines are run at thread exit.
* 2008-02-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-02-061-0/+32
* posix/src/mqueueunlink.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl: Enhance _Objects_Namespace_remove() to handle freeing object names which are strings. All changed _Objects_Close() to call _Objects_Namespace_remove(). The resulting code was then moved from inline routines to function calls. * score/src/objectclose.c, score/src/objectnamespaceremove.c: New files.
