2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2020-12-02 | score: Canonicalize Doxygen @file comments | Sebastian Huber | 1 | -2/+5 | |
Use common phrases for the file brief descriptions. Update #3706. | |||||
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2020-02-12 | score: Split up objects allocation | Sebastian Huber | 1 | -4/+12 | |
Split up the different objects allocation methods into separate functions. This helps to avoid a dependency on the workspace in case no objects or a static set of objects is configured. Change license to BSD-2-Clause according to file histories. Update #3053. Update #3835. | |||||
2020-02-06 | config: Add CONFIGURE_DIRTY_MEMORY | Sebastian Huber | 1 | -2/+2 | |
Replace the BSP_DIRTY_MEMORY BSP option with a CONFIGURE_DIRTY_MEMORY configuration option. Update #3843. | |||||
2020-02-06 | sysinit: Add RTEMS_SYSINIT_ZERO_MEMORY | Sebastian Huber | 1 | -13/+6 | |
Use a dedicate system initialization step to zero the memory used for the workspace and C program heap. This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is not configured. | |||||
2018-12-20 | psxhdrs: Changing copyright license to BSD-2-Clause | Jacob Shin | 1 | -11/+22 | |
2018-12-09 | psxhdrs: Add POSIX API Signature Compliance Tests for stdlib.h (GCI 2018) | Jacob Shin | 1 | -6/+4 | |
2018-12-05 | psxhdrs: Fix spacing | Joel Sherrill | 1 | -16/+16 | |
2018-12-05 | psxhdrs: POSIX API Signature Compliance Tests for assert.h (GCI 2018) | Jacob Shin | 1 | -6/+4 | |
2018-12-04 | psxhdrs: POSIX API Signature Compliance Tests for ulimit.h (GCI 2018) | Jacob Shin | 1 | -5/+6 | |
2018-12-04 | psxhdrs: Implement POSIX API Signature Compliance Tests for iconv.h (GCI 2018) | Jacob Shin | 1 | -4/+6 | |
2018-12-03 | psxhdrs: Implement POSIX API Signature Compliance Tests for fnmatch.h (GCI 2018) | Jacob Shin | 1 | -14/+7 | |
GCI Username: deuteriumoxide | |||||
2018-12-02 | psxhdrs:Add POSIX conformance test for utime.h (GCI 2018) | Shashvat Jain | 1 | -15/+17 | |
2018-11-27 | psxtests: add POSIX API signature compliance tests for dirent.h file (GCI 2018) | Himanshu40 | 1 | -0/+39 | |
