Add RTEMS_PREDICT_TRUE() and RTEMS_PREDICT_FALSE() for static branch
prediction hints.
Close #3475.
Update #3117.
Update #3182.
Rename _Thread_queue_Context_set_do_nothing_enqueue_callout() into
_Thread_queue_Context_set_enqueue_do_nothing_extra(). More
_Thread_queue_Context_set_enqueue_*() functions will follow.
Update #3117.
Update #3182.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
Update #2858.
Add thread state bit to identify thread queues that are embedded in an
object with identifier.
Only require that the Newlib defined structure is big enough.
Move thread state for _Thread_queue_Enqueue() to the thread queue
context. This reduces the parameter count of _Thread_queue_Enqueue()
from five to four (ARM for example has only four function parameter
registers). Since the thread state is used after several function calls
inside _Thread_queue_Enqueue() this parameter was saved on the stack
previously.
Delete unused _Thread_queue_Enqueue() and rename
_Thread_queue_Enqueue_critical() to _Thread_queue_Enqueue().
Replace the expected thread dispatch disable level with a thread queue
enqueue callout. This enables the use of _Thread_Dispatch_direct() in
the thread queue enqueue procedure. This avoids impossible exection
paths, e.g. Per_CPU_Control::dispatch_necessary is always true.
Avoid use of the stack for the hot paths.
This makes it easier to conditionally enable/disable the thread resource
count usage.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
Add _Thread_queue_Surrender() to unify the mutex surrender procedures
which involve a thread queue operation.
The mutex objects use the owner field of the thread queues for the mutex
owner. Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
Close #2765.
Move the priority change due to priority interitance to the thread queue
enqueue operation to simplify the locking on SMP configurations.
Update #2412.
Update #2556.
Update #2765.
Raise the priority under thread queue lock protection and omit the
superfluous thread queue priority change, since the thread is extracted
anyway. The unblock operation will pick up the new priority.
Update #2412.
Update #2556.
Update #2765.
updates #2745
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Adjust thread queue layout according to Newlib. This makes it possible
to use the same implementation for <sys/lock.h> and CORE mutexes in the
future.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
We must call the MP callout for proxies if we unblock them after a
thread queue extraction. This was missing in
_Thread_queue_Flush_critical(). Move thread remove timer and unblock
code to new function _Thread_Remove_timer_and_unblock().
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
This fixes a copy and paste error (from libbsd).
This mutex implementation uses a thread priority queue with a simple
priority inheritance mechanism (similar to the object based mutexes).
The storage space must be supplied by the user (16 bytes on 32-bit
targets).
