path: root/cpukit/score/src/iterateoverthreads.c (unfollow)
2022-02-28score/src/[a-m]*.c: Change license to BSD-2Joel Sherrill1-3/+22
Updates #3053.
2020-12-02score: Canonicalize Doxygen @file commentsSebastian Huber1-3/+5
Use common phrases for the file brief descriptions. Update #3706.
2020-04-16Canonicalize config.h includeSebastian Huber1-1/+1
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2019-04-04doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber1-1/+1
Update #3706
2016-11-02rtems: Add rtems_task_iterate()Sebastian Huber1-27/+18
Update #2423.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-07-26score: Create object implementation headerSebastian Huber1-1/+1
Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API.
2012-12-01score misc: Score misc: Clean up Doxygen #11 (GCI 2012)Daniel Georgiev1-6/+7
This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013204
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2010-11-232010-11-23 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber1-5/+4
* score/src/iterateoverthreads.c, libmisc/cpuuse/cpuusagereport.c: Avoid dead code if POSIX API is enabled.
2010-11-232010-11-23 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber1-5/+3
* score/src/iterateoverthreads.c, libmisc/cpuuse/cpuusagereport.c: Fixed NULL pointer access in case POSIX API is disabled.
2010-07-262010-07-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+8
* libcsupport/src/privateenv.c, libmisc/cpuuse/cpuusagereport.c, posix/Makefile.am, posix/include/rtems/posix/key.h, posix/src/keycreate.c, posix/src/keydelete.c, score/src/iterateoverthreads.c: Since removing ITRON, the loop over all APIs for tasks has a path that cannot be reached. Either modify the code or mark tests for NULL as RTEMS_DEBUG. * posix/src/keyfreememory.c: New file.
2009-07-232009-07-23 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-10/+10
* score/src/iterateoverthreads.c: Restructure a bit to make analysis easier.
2007-04-052007-04-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+3
* itron/src/itrontime.c: Fix typo. * score/include/rtems/score/tod.h: Add TOD_TICKS_PER_SECOND macro. * score/src/iterateoverthreads.c: Safely take NULL as argument. * score/src/threaddispatch.c: Formatting.
2005-01-27Include config.h.Ralf Corsepius1-0/+4
2004-04-17Remove stray white spaces.Ralf Corsepius1-4/+4
2004-03-292004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-2/+2
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapsizeofuserarea.c, score/src/interr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadget.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstart.c, score/src/userext.c, score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using c99 fixed size types.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
2003-08-142003-08-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+46
PR 408/filesystem * score/Makefile.am, score/include/rtems/score/thread.h: Added sync() service. As part of adding this service, the new RTEMS service rtems_iterate_over_all_threads() was also added. This new service makes it easier to iterate over all the tasks/threads in a system and perform an action on them. * score/src/iterateoverthreads.c: New file. * ChangeLog: Fixed screwup.
