path: root/cpukit/score/src/ioprintf.c (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-0/+9
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Add _IO_Printf() and _IO_Vprintf()Sebastian Huber2017-11-061-0/+31
The previous vprintk() implementation had a questionable licence header, lacks support for the 'z' and 'j' format specifiers, is not robust against invalid format specifiers, uses a global variable for output. Replace it with a stripped down version of the FreeBSD kernel kvprintf() function. The new implementation allows a low overhead rtems_snprintf() if necessary. Update #3199. Close #3216.
