* | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | 2019-04-04 | 1 | -1/+1 |
| | | | | Update #3706 | ||||
* | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | 2015-10-26 | 1 | -4/+4 |
* | score: Create heap implementation header | Sebastian Huber | 2013-07-23 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of heap.h and heap.inl into new header file heapimpl.h. The heap.h contains now only the application visible API. | ||||
* | score: Change _Heap_Extend() API | Sebastian Huber | 2012-10-25 | 1 | -0/+37 |
The _Heap_Extend() has now the same signature as _Heap_Initialize(). The 4th parameter is ignored (page size in _Heap_Initialize()). Add Heap_Area and Heap_Initialization_or_extend_handler. Add and test _Heap_No_extend(). This helps to do a table based heap initialization and extension. Create a table of Heap_Area elements and iterate through it. Set the handler to _Heap_Initialize() in the first iteration and then to _Heap_Extend(). |
