Move implementation specific parts of heap.h and heap.inl into new
header file heapimpl.h. The heap.h contains now only the application
visible API.
* score/src/heapiterate.c, score/src/pheapiterate.c: New files.
* score/Makefile.am: Reflect changes above.
* score/include/rtems/score/heap.h: Declare _Heap_Iterate() and define
Heap_Block_visitor.
* score/include/rtems/score/protectedheap.h: Declare
_Protected_heap_Iterate().
* score/src/heapgetinfo.c: Use _Heap_Iterate().
