* | Score misc: Clean up Doxygen #4 (GCI 2012) | Alexandre Devienne | 2012-11-28 | 1 | -0/+8 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7985215 | ||||
* | score: Change greedy allocation API | Sebastian Huber | 2012-07-17 | 1 | -8/+25 |
* | Added support functions for greedy heap allocation | Sebastian Huber | 2012-02-10 | 1 | -0/+62 |
Various tests must check program paths that result due to failed memory allocations from the heap. To avoid tinkering with internal heap structures throughout the test code these functions should be used. |
