* libcsupport/src/free.c, libmisc/stackchk/check.c,
rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c,
rtems/src/regionextend.c, rtems/src/regiongetinfo.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionresizesegment.c, score/src/pheapallocate.c,
score/src/pheapallocatealigned.c, score/src/pheapextend.c,
score/src/pheapfree.c, score/src/pheapgetblocksize.c,
score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c,
score/src/pheapgetsize.c, score/src/pheapinit.c,
score/src/pheapresizeblock.c, score/src/pheapwalk.c:
Update for heap API changes.
* score/include/rtems/score/apimutex.h,
score/include/rtems/score/object.h: Documentation.
* score/include/rtems/score/heap.h,
score/include/rtems/score/protectedheap.h,
score/inline/rtems/score/heap.inl, score/src/heap.c,
score/src/heapallocate.c, score/src/heapallocatealigned.c,
score/src/heapextend.c, score/src/heapfree.c,
score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c,
score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c,
score/src/heapwalk.c: Overall cleanup. Added boundary constraint to
allocation function. More changes follow.
* libmisc/stackchk/check.c, rtems/src/regionreturnsegment.c,
rtems/src/regiongetsegmentsize.c, src/heapalignupuptr.c,
src/heapallocatealigned.c, src/heapallocate.c, src/heap.c,
src/heapextend.c, src/heapfree.c, src/heapgetfreeinfo.c,
src/heapgetinfo.c, src/heapresizeblock.c, src/heapsizeofuserarea.c,
src/heapwalk.c, src/pheapgetblocksize.c, inline/rtems/score/heap.inl,
include/rtems/score/heap.h: Overall cleanup. Changed all types for
addresses, sizes, offsets and alignments to uintptr_t. Reformatted.
Added variables for clarity. Renamed various objects. Enabled
_HAssert() for all instances. More changes follow.
PR 536/rtems
Heap manager re-implementation to consume less memory and still satisfy
alignment requirements.
* score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapgetinfo.c,
score/src/heapgetfreeinfo.c, core/src/heapsizeofuserarea.c,
score/src/heapwalk.c, core/macros/rtems/score/heap.inl,
score/include/rtems/score/heap.h: Reimplemented.
* score/src/heapallocatealigned.c: new file
* score/Makefile.am: HEAP_C_FILES: add score/src/heapallocatealigned.c
PR 740/rtems
* score/src/heapgetfreeinfo.c: Return size of largest not of last block.
* libcsupport/src/mallocfreespace.c, rtems/Makefile.am,
rtems/include/rtems/rtems/region.h, score/Makefile.am,
score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add
capability to return information about just the free blocks in a
region or heap. Also changed the semantics of free space available
to be the largest block of memory that can be allocated.
* rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files.
: score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove warning.
