path: root/cpukit/score/src/heapallocate.c (follow)
* score: Merge sysstate API into one fileSebastian Huber2013-07-241-1/+0
* score: Create heap implementation headerSebastian Huber2013-07-231-1/+1
| | | | | | Move implementation specific parts of heap.h and heap.inl into new header file heapimpl.h. The heap.h contains now only the application visible API.
* 2010-08-25 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-251-31/+82
| | | | | | | | | PR 1672/cpukit * score/include/rtems/score/heap.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c: Added heap protection in case RTEMS_DEBUG is defined.
* 2009-09-09 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-09-091-4/+3
| | | | | | | | | * score/include/rtems/score/heap.h, score/inline/rtems/score/heap.inl, score/src/heapallocate.c, score/src/heap.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapwalk.c: Documenation. Simplified block resize. Improved heap walk. Changed heap layout to avoid a special case for _Heap_Is_used() and _Heap_Is_free(). * libmisc/stackchk/check.c: Update for heap API changes.
* 2009-09-06 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-09-061-25/+189
| | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/free.c, libmisc/stackchk/check.c, rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapgetsize.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: Update for heap API changes. * score/include/rtems/score/apimutex.h, score/include/rtems/score/object.h: Documentation. * score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/inline/rtems/score/heap.inl, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/heapwalk.c: Overall cleanup. Added boundary constraint to allocation function. More changes follow.
* 2009-08-24 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-08-261-47/+32
| | | | | | | | | | | | | * libmisc/stackchk/check.c, rtems/src/regionreturnsegment.c, rtems/src/regiongetsegmentsize.c, src/heapalignupuptr.c, src/heapallocatealigned.c, src/heapallocate.c, src/heap.c, src/heapextend.c, src/heapfree.c, src/heapgetfreeinfo.c, src/heapgetinfo.c, src/heapresizeblock.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/pheapgetblocksize.c, inline/rtems/score/heap.inl, include/rtems/score/heap.h: Overall cleanup. Changed all types for addresses, sizes, offsets and alignments to uintptr_t. Reformatted. Added variables for clarity. Renamed various objects. Enabled _HAssert() for all instances. More changes follow.
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-141-1/+1
| | | | | | | | | | | | | | | | * libcsupport/src/realloc.c, rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionmp.c, rtems/src/regionresizesegment.c, sapi/include/rtems/config.h, score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapgetblocksize.c, score/src/pheapresizeblock.c: Change sizes of heap/region and allocated objects in heap to intptr_t so they can be larger than a single allocatable object (e.g. size_t).
* 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-201-1/+1
| | | | | | | | | | | | | | * score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/include/rtems/score/wkspace.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c, score/src/wkspace.c: Revert use of ssize_t. This type is not guaranteed to be able to represent a positive number greater than the size of a single allocatable object. We needed a type that is able to represent the size of a pool of multiple allocatable objects or potentially nearly all memory.
* 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-021-1/+1
| | | | | | | | | | | | | | | | | * libcsupport/src/malloc_statistics_helpers.c, libcsupport/src/realloc.c, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/support.h, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, rtems/src/workspace.c, sapi/include/confdefs.h, score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/include/rtems/score/wkspace.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c, score/src/wkspace.c: Change size_t to ssize_t on all Heap, Workspace and Region calls. On 16-bit architectures, size_t can be 16-bits which would limit sizes to 64K.
* Use size_t for heap-sizes.Ralf Corsepius2007-02-111-1/+1
* 2005-05-14 Sergei Organov <osv@topconrd.ru>Joel Sherrill2005-05-201-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 746/rtems Optimize realloc(). The problem is that realloc() can neither grow nor shrink efficiently the current memory region without support from underlying heap/region modules. The patch introduces one new routine for each of heap and region modules, _Heap_Resize_block(), and rtems_region_resize_segment(), respectively, and uses the latter to optimize realloc(). The implementation of _Heap_Resize_block() lead to changing of the heap allocation strategy: now the heap manager, when splits larger free block into used and new free parts, makes the first part of the block used, not the last one as it was before. Due to this new strategy, _Heap_Resize_block() never needs to change the user pointer. Caveat: unlike previous heap implementation, first few bytes of the contents of the memory allocated from the heap are now almost never all zero. This can trigger bugs in client code that have not been visible before this patch. * libcsupport/src/malloc.c (realloc): try to resize segment in place using new rtems_region_resize_segment() routine before falling back to the malloc()/free() method. * score/src/heap.c: (_Heap_Initialize): change initial heap layout to reflect new allocation strategy of using of the lower part of a previously free block when splitting it for the purpose of allocation. (_Heap_Block_allocate): when split, make the lower part used, and leave the upper part free. Return type changed from Heap_Block* to uint32_t. * score/include/rtems/score/heap.h: (Heap_Statistics): added 'resizes' field. (Heap_Resize_status): new enum. (_Heap_Resize_block): new routine. (_Heap_Block_allocate): return type changed from Heap_Block* to uint32_t. * score/src/heapwalk.c: reflect new heap layout in checks. * score/src/heapsizeofuserarea.c: more assertions added. * score/src/heapresizeblock.c: new file. (_Heap_Resize_block): new routine. * score/src/heapfree.c: reverse the checks _Heap_Is_block_in() and _Heap_Is_prev_used() on entry to be in this order. * score/src/heapallocate.c, score/src/heapallocatealigned.c: ignore return value of _Heap_Block_allocate(). * score/Makefile.am (HEAP_C_FILES): added src/heapresizeblock.c. * rtems/include/rtems/rtems/region.h: (rtems_region_resize_segment): new interface routine. (_Region_Process_queue): new internal routine called from rtems_region_resize_segment() and rtems_region_return_segment(). * rtems/src/regionreturnsegment.c: move queue management code into the new internal routine _Region_Process_queue() and call it. * rtems/src/regionresizesegment.c: new file. (rtems_region_resize_segment): new interface routine. * rtems/src/regionprocessqueue.c: new file. (_Region_Process_queue): new internal routine containing queue management code factored out from 'regionreturnsegment.c'. * rtems/Makefile.am (REGION_C_FILES): Added src/regionresizesegment.c, and src/regionprocessqueue.c. * ada/rtems.adb, ada/rtems.ads: Added Region_Resize_Segment.
* Include config.h.Ralf Corsepius2005-01-271-0/+3
* 2005-01-20 Sergei Organov <osv@topconrd.ru>Joel Sherrill2005-01-201-64/+29
| | | | | | | | | | | | | | | | PR 536/rtems Heap manager re-implementation to consume less memory and still satisfy alignment requirements. * score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetinfo.c, score/src/heapgetfreeinfo.c, core/src/heapsizeofuserarea.c, score/src/heapwalk.c, core/macros/rtems/score/heap.inl, score/inline/rtems/score/heap.inl, score/include/rtems/score/heap.h: Reimplemented. * score/src/heapallocatealigned.c: new file * score/Makefile.am: HEAP_C_FILES: add score/src/heapallocatealigned.c
* Remove stray white spaces.Ralf Corsepius2004-04-171-3/+3
* Remove stray white spaces.Ralf Corsepius2004-04-151-1/+0
* 2004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-291-9/+9
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapsizeofuserarea.c, score/src/interr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadget.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstart.c, score/src/userext.c, score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using c99 fixed size types.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
* 2000-11-28 Chris Johns <ccj@acm.org>Joel Sherrill2000-11-281-1/+9
| | | | | | | | | * src/heapallocate.c: Do not allow the size to overflow when adjusting it. A test allocated a stack of -1 (~0). This actually resulted in a stack being allocated but with a size of 0xb. The allocator did not test the size to see if it rolled through 0 and so allowed the allocation to happen, the thread to get created. The task crashed as you would expect.
* Split Heap and Time of Day Handlers.Joel Sherrill1999-11-021-0/+107
