Determine the next block only once and use it throughout.
Update #3806.
Update #3706
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
This value depends on the _Heap_Initialize() call sequence and carries
no useful information.
Add and use _Heap_Protection_set_delayed_free_fraction(). This makes it
possible to avoid a dependency on _Thread_Dispatch_is_enabled().
Rename _Internal_error_Occurred() into _Terminate().
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of heap.h and heap.inl into new
header file heapimpl.h. The heap.h contains now only the application
visible API.
* score/src/heap.c: Avoid integer overflow.
* libmisc/stackchk/check.c: Make compile again.
* sapi/src/io.c, score/src/heap.c: Address dead assignment
issues found by clang.
PR 1672/cpukit
* score/include/rtems/score/heap.h, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapresizeblock.c,
score/src/heapsizeofuserarea.c: Added heap protection in case
RTEMS_DEBUG is defined.
* score/include/rtems/score/heap.h: Declare
_Heap_Get_first_and_last_block(). Removed Heap_Extend_status.
Changed return type of _Heap_Extend() to bool.
* score/inline/rtems/score/heap.inl: Define
_Heap_Set_last_block_size().
* score/src/heap.c: Define and use _Heap_Get_first_and_last_block().
* score/src/heapgetinfo.c: Removed assert statements. Do not count
the last block. This ensures that all size values are an integral
multiple of the page size which is consistent with the other
statistics.
* score/src/heapextend.c: Implemented support for scattered heap
areas.
* score/src/heapwalk.c: Dump also last block. Changes for new first
and last block values.
* ./score/src/pheapextend.c, rtems/src/regionextend.c: Update for
_Heap_Extend() changes.
* score/src/heap.c, score/include/rtems/score/heap.h: Reduced alignment
requirement for CPU_ALIGNMENT from four to two.
* score/include/rtems/score/heap.h, score/inline/rtems/score/heap.inl,
score/src/heapallocate.c, score/src/heap.c, score/src/heapextend.c,
score/src/heapresizeblock.c, score/src/heapwalk.c: Documenation.
Simplified block resize. Improved heap walk. Changed heap layout to
avoid a special case for _Heap_Is_used() and _Heap_Is_free().
* libmisc/stackchk/check.c: Update for heap API changes.
* libcsupport/src/free.c, libmisc/stackchk/check.c,
rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c,
rtems/src/regionextend.c, rtems/src/regiongetinfo.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionresizesegment.c, score/src/pheapallocate.c,
score/src/pheapallocatealigned.c, score/src/pheapextend.c,
score/src/pheapfree.c, score/src/pheapgetblocksize.c,
score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c,
score/src/pheapgetsize.c, score/src/pheapinit.c,
score/src/pheapresizeblock.c, score/src/pheapwalk.c:
* score/include/rtems/score/apimutex.h,
score/include/rtems/score/object.h: Documentation.
score/include/rtems/score/protectedheap.h,
score/inline/rtems/score/heap.inl, score/src/heap.c,
score/src/heapallocate.c, score/src/heapallocatealigned.c,
score/src/heapextend.c, score/src/heapfree.c,
score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c,
score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c,
score/src/heapwalk.c: Overall cleanup. Added boundary constraint to
allocation function. More changes follow.
* libmisc/stackchk/check.c, rtems/src/regionreturnsegment.c,
rtems/src/regiongetsegmentsize.c, src/heapalignupuptr.c,
src/heapallocatealigned.c, src/heapallocate.c, src/heap.c,
src/heapextend.c, src/heapfree.c, src/heapgetfreeinfo.c,
src/heapgetinfo.c, src/heapresizeblock.c, src/heapsizeofuserarea.c,
src/heapwalk.c, src/pheapgetblocksize.c, inline/rtems/score/heap.inl,
include/rtems/score/heap.h: Overall cleanup. Changed all types for
addresses, sizes, offsets and alignments to uintptr_t. Reformatted.
Added variables for clarity. Renamed various objects. Enabled
_HAssert() for all instances. More changes follow.
* score/src/heap.c: Remove unneeded include.
* libcsupport/src/realloc.c, rtems/include/rtems/rtems/region.h,
rtems/src/regioncreate.c, rtems/src/regionextend.c,
rtems/src/regionmp.c, rtems/src/regionresizesegment.c,
sapi/include/rtems/config.h, score/include/rtems/score/heap.h,
score/include/rtems/score/protectedheap.h, score/src/heap.c,
score/src/heapextend.c, score/src/heapresizeblock.c,
score/src/heapsizeofuserarea.c, score/src/pheapallocate.c,
score/src/pheapgetblocksize.c, score/src/pheapresizeblock.c: Change
sizes of heap/region and allocated objects in heap to intptr_t so
they can be larger than a single allocatable object (e.g. size_t).
score/include/rtems/score/wkspace.h, score/src/heap.c,
score/src/heapsizeofuserarea.c, score/src/pheapgetblocksize.c,
score/src/wkspace.c: Revert use of ssize_t. This type is not
guaranteed to be able to represent a positive number greater than the
size of a single allocatable object. We needed a type that is able to
represent the size of a pool of multiple allocatable objects or
potentially nearly all memory.
* libcsupport/src/malloc_statistics_helpers.c,
rtems/include/rtems/rtems/support.h,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/workspace.c, sapi/include/confdefs.h,
score/src/wkspace.c: Change size_t to ssize_t on all Heap, Workspace
and Region calls. On 16-bit architectures, size_t can be 16-bits
which would limit sizes to 64K.
PR 1258/rtems
* cpukit/score/src/heapallocatealigned.c (block_allocate): New routine.
* cpukit/score/src/heapallocatealigned.c (_Heap_Allocate_aligned):
Use block_allocate() instead of _Heap_Block_allocate(). Replace
_Heap_Head(the_heap)->next with equivalent _Heap_First(the_heap).
* cpukit/score/src/heap.c (_Heap_Allocate): fix comments according
to changed block split strategy in _Heap_Allocate_aligned().
* score/src/heap.c: Style.
* score/src/heapwalk.c: Add more information to prints.
* score/src/pheapwalk.c: Do not lock allocator mutex if dispatching
is disabled.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
PR 746/rtems
Optimize realloc(). The problem is that realloc() can neither grow
nor shrink efficiently the current memory region without support
from underlying heap/region modules. The patch introduces one new
routine for each of heap and region modules, _Heap_Resize_block(),
and rtems_region_resize_segment(), respectively, and uses the
latter to optimize realloc().
The implementation of _Heap_Resize_block() lead to changing of the
heap allocation strategy: now the heap manager, when splits larger
free block into used and new free parts, makes the first part of
the block used, not the last one as it was before. Due to this new
strategy, _Heap_Resize_block() never needs to change the user
pointer.
Caveat: unlike previous heap implementation, first few bytes of
the contents of the memory allocated from the heap are now almost
never all zero. This can trigger bugs in client code that have not
been visible before this patch.
* libcsupport/src/malloc.c (realloc): try to resize segment in
place using new rtems_region_resize_segment() routine before
falling back to the malloc()/free() method.
* score/src/heap.c:
(_Heap_Initialize): change initial heap layout to reflect new
allocation strategy of using of the lower part of a previously
free block when splitting it for the purpose of allocation.
(_Heap_Block_allocate): when split, make the lower part used, and
leave the upper part free. Return type changed from Heap_Block* to
uint32_t.
(Heap_Statistics): added 'resizes' field.
(Heap_Resize_status): new enum.
(_Heap_Resize_block): new routine.
(_Heap_Block_allocate): return type changed from Heap_Block* to
uint32_t.
* score/src/heapwalk.c: reflect new heap layout in checks.
* score/src/heapsizeofuserarea.c: more assertions added.
* score/src/heapresizeblock.c: new file.
* score/src/heapfree.c: reverse the checks _Heap_Is_block_in() and
_Heap_Is_prev_used() on entry to be in this order.
* score/src/heapallocate.c, score/src/heapallocatealigned.c:
ignore return value of _Heap_Block_allocate().
* score/Makefile.am (HEAP_C_FILES): added src/heapresizeblock.c.
* rtems/include/rtems/rtems/region.h:
(rtems_region_resize_segment): new interface routine.
(_Region_Process_queue): new internal routine called from
rtems_region_resize_segment() and rtems_region_return_segment().
* rtems/src/regionreturnsegment.c: move queue management code into
the new internal routine _Region_Process_queue() and call it.
* rtems/src/regionresizesegment.c: new file.
* rtems/src/regionprocessqueue.c: new file.
(_Region_Process_queue): new internal routine containing queue
management code factored out from 'regionreturnsegment.c'.
* rtems/Makefile.am (REGION_C_FILES): Added
src/regionresizesegment.c, and src/regionprocessqueue.c.
* ada/rtems.adb, ada/rtems.ads: Added Region_Resize_Segment.
PR 536/rtems
Heap manager re-implementation to consume less memory and still satisfy
alignment requirements.
* score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapgetinfo.c,
score/src/heapgetfreeinfo.c, core/src/heapsizeofuserarea.c,
score/src/heapwalk.c, core/macros/rtems/score/heap.inl,
score/include/rtems/score/heap.h: Reimplemented.
* score/src/heapallocatealigned.c: new file
* score/Makefile.am: HEAP_C_FILES: add score/src/heapallocatealigned.c
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
to be able to build a system without requiring printf.
Thread_Close fixed to avoid returning FP context area when one was not
allocated at initialization time.
