path: root/cpukit/score/src/heap.c (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-2/+2
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-16/+24
* Initial revisionJoel Sherrill1995-05-111-0/+478
