Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
