Update #3082.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
of this patch set.
This new Score Handler provides a structure to manage a
cpu_set_t plus helper routines to validate the contents
against the current system configuration.
