comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
PR 1895/cpukit
* score/src/coretodmsecstoticks.c, score/src/coretodusectoticks.c,
score/src/timespectoticks.c: Ensure time conversions to ticks do not
ignore partial tick and return 1 less than desired.
* libblock/src/bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/mw-fb/mw_uid.c,
rtems/include/rtems/rtems/support.h, score/Makefile.am,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodtickle.c: Eliminate all public use of TOD conversion
routines. Eliminate _TOD_Microseconds_per_tick and let every place
use the field directly from the Configuration Table. This required
moving some methods from macros to bodies.
* score/src/coretodmsecstoticks.c, score/src/coretodtickspersec.c,
score/src/coretodusectoticks.c: New files.
