Use the timestamps only for uptime based values. Use struct timespec
for the absolute time values (TOD).
Update #2740.
Update #2555.
Update #2630.
Rename _TOD_Set() into _TOD_Set_with_timespec(). Rename
_TOD_Set_with_timestamp() into _TOD_Set(). This is now in line with
_TOD_Get() and _TOD_Get_as_timespec(). The timestamp is the canonical
format.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
This lays the proper structure for doing future work on
time adjustment algorithms. Any TOD adjustments should be
requested at the API level and performed at the SCORE level.
Additionally updated a test.
