path: root/cpukit/score/src/coretod.c (follow)
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-011-2/+1
| | | | are automatically activated upon insertion.
* posix support initially addedJoel Sherrill1995-09-261-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-15/+15
* Initial revisionJoel Sherrill1995-05-111-0/+236
