Two issues are addressed.
1. On single processor configurations the set/get of the now/uptime
timestamps is now consistently protected by ISR disable/enable
sequences. Previously nested interrupts could observe partially written
values since 64-bit writes are not atomic on 32-bit architectures in
general. This could lead to non-monotonic uptime timestamps.
2. The TOD now/uptime maintanence is now independent of the giant lock.
This is the first step to remove the giant lock in _Thread_Dispatch().
Move the nanoseconds since last tick support from the Watchdog to the
TOD handler. Now the TOD managment is encapsulated in the TOD_Control
structure.
TOD_MILLISECONDS_TO_TICKS().
application visible API.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set)
in a structure to reduce address loads in _TOD_Tickle_ticks().
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c,
score/include/rtems/score/mpci.h, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h, score/src/coretod.c,
score/src/mpci.c, score/src/object.c, score/src/thread.c,
score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
* libblock/src/bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/mw-fb/mw_uid.c,
rtems/include/rtems/rtems/support.h, score/Makefile.am,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodtickle.c: Eliminate all public use of TOD conversion
routines. Eliminate _TOD_Microseconds_per_tick and let every place
use the field directly from the Configuration Table. This required
moving some methods from macros to bodies.
* score/src/coretodmsecstoticks.c, score/src/coretodtickspersec.c,
score/src/coretodusectoticks.c: New files.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c,
posix/src/pthread.c, posix/src/timersettime.c,
rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c,
rtems/src/timerfirewhen.c, rtems/src/timerserver.c,
rtems/src/timerserverfirewhen.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/thread.h,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c,
score/src/threaddispatch.c, score/src/threadinitialize.c: Add
SuperCore handler Timestamp to provide an opaque class for the
representation and manipulation of uptime, time of day, and the
difference between two timestamps. By using SuperCore Timestamp, it
is clear which methods and APIs really have to be struct timespec and
which can be in an optimized native format.
* score/include/rtems/score/timestamp.h,
score/src/coretodgetuptimetimespec.c: New files.
* posix/Makefile.am, posix/include/rtems/posix/time.h,
posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c,
posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c,
posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c,
posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c,
posix/src/sched.c, posix/src/semtimedwait.c,
posix/src/sigtimedwait.c, posix/src/ualarm.c,
rtems/src/clocktodtoseconds.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c,
score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec
manipulation routines in the SuperCore. Use them everywhere possible.
This lead to significant cleanup in the API routines and eliminated
some of the same code from the POSIX API. At this point, the
SuperCore keeps time in POSIX timespec format properly from 1970. You
just cannot set it before 1988 in keeping with RTEMS traditional
behavior.
* score/include/rtems/score/timespec.h, score/src/timespecaddto.c,
score/src/timespecfromticks.c, score/src/timespecisvalid.c,
score/src/timespeclessthan.c, score/src/timespecsubtract.c,
score/src/timespectoticks.c: New files.
* posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c: Removed.
* posix/include/rtems/posix/timer.h, posix/src/alarm.c,
posix/src/posixtimespectointerval.c, posix/src/ptimer1.c,
posix/src/sysconf.c, posix/src/ualarm.c, rtems/src/clockget.c,
rtems/src/clocktodvalidate.c, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c: Eliminate
TOD_Ticks_per_second variable.
* itron/src/itrontime.c, libcsupport/src/__gettod.c,
posix/src/clockgettime.c, posix/src/clocksettime.c,
posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c,
posix/src/sleep.c, rtems/Makefile.am,
rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c,
score/Makefile.am, score/include/rtems/score/tod.h,
score/src/coretodset.c: Convert from Classic API style TOD_Control as
fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* rtems/src/clockgetuptime.c, score/src/coretodget.c,
score/src/coretodgetuptime.c: New files.
* score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c: Removed.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
are automatically activated upon insertion.
like signal dispatching.
