* | posix: Implement self-contained POSIX rwlocks | Sebastian Huber | 2017-10-05 | 1 | -11/+6 |
| | | | | | | | | POSIX rwlocks are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3115. | ||||
* | score: Add _Thread_queue_Object_name | Sebastian Huber | 2017-01-31 | 1 | -1/+1 |
| | | | | | | | | | | | | | Add the special thread queue name _Thread_queue_Object_name to mark thread queues embedded in an object with identifier. Using the special thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for this purpose since the thread wait information and thread state are protected by different SMP locks in separate critical sections. Remove STATES_THREAD_QUEUE_WITH_IDENTIFIER. Add and use _Thread_queue_Object_initialize(). Update #2858. | ||||
* | score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER | Sebastian Huber | 2017-01-11 | 1 | -1/+1 |
| | | | | | Add thread state bit to identify thread queues that are embedded in an object with identifier. | ||||
* | score: Optimize _Thread_queue_Enqueue() | Sebastian Huber | 2016-11-24 | 1 | -1/+4 |
| | | | | | | | | | Move thread state for _Thread_queue_Enqueue() to the thread queue context. This reduces the parameter count of _Thread_queue_Enqueue() from five to four (ARM for example has only four function parameter registers). Since the thread state is used after several function calls inside _Thread_queue_Enqueue() this parameter was saved on the stack previously. | ||||
* | score: Rename _Thread_queue_Enqueue_critical() | Sebastian Huber | 2016-11-23 | 1 | -1/+1 |
| | | | | | Delete unused _Thread_queue_Enqueue() and rename _Thread_queue_Enqueue_critical() to _Thread_queue_Enqueue(). | ||||
* | score: Add thread queue enqueue callout | Sebastian Huber | 2016-11-23 | 1 | -1/+1 |
| | | | | | | | Replace the expected thread dispatch disable level with a thread queue enqueue callout. This enables the use of _Thread_Dispatch_direct() in the thread queue enqueue procedure. This avoids impossible exection paths, e.g. Per_CPU_Control::dispatch_necessary is always true. | ||||
* | cpukit: Add and use Watchdog_Discipline. | Gedare Bloom | 2016-07-25 | 1 | -2/+0 |
| | | | | | | | | | Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE, or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline of WATCHDOG_NO_TIMEOUT. updates #2732 | ||||
* | score: _CORE_mutex_Check_dispatch_for_seize() | Sebastian Huber | 2016-05-30 | 1 | -1/+2 |
| | | | | | | | | | | | Move the safety check performed by _CORE_mutex_Check_dispatch_for_seize() out of the performance critical path and generalize it. Blocking on a thread queue with an unexpected thread dispatch disabled level is illegal in all system states. Add the expected thread dispatch disable level (which may be 1 or 2 depending on the operation) to Thread_queue_Context and use it in _Thread_queue_Enqueue_critical(). | ||||
* | score: Add Status_Control for all APIs | Sebastian Huber | 2016-05-26 | 1 | -10/+7 |
| | | | | | | | | | | | Unify the status codes of the Classic and POSIX API to use the new enum Status_Control. This eliminates the Thread_Control::Wait::timeout_code field and the timeout parameter of _Thread_queue_Enqueue_critical() and _MPCI_Send_request_packet(). It gets rid of the status code translation tables and instead uses simple bit operations to get the status for a particular API. This enables translation of status code constants at compile time. Add _Thread_Wait_get_status() to avoid direct access of thread internal data structures. | ||||
* | score: Move thread queue MP callout to context | Sebastian Huber | 2016-05-25 | 1 | -10/+10 |
| | | | | | | | | Drop the multiprocessing (MP) dependent callout parameter from the thread queue extract, dequeue, flush and unblock methods. Merge this parameter with the lock context into new structure Thread_queue_Context. This helps to gets rid of the conditionally compiled method call helpers. | ||||
* | score: Avoid Giant lock for CORE rwlock | Sebastian Huber | 2016-04-22 | 1 | -50/+48 |
| | | | | Update #2555. | ||||
* | score: Rename _CORE_RWLock_Obtain() | Sebastian Huber | 2016-04-21 | 1 | -1/+1 |
| | | | | | | | | Rename _CORE_RWLock_Obtain_for_reading() into _CORE_RWLock_Seize_for_reading(). Rename _CORE_RWLock_Obtain_for_writing() into _CORE_RWLock_Seize_for_writing(). Rename _CORE_RWLock_Release() into _CORE_RWLock_Surrender(). This avoids confusion with the ISR lock acquire and release. | ||||
* | score: Delete MP support for RW locks | Sebastian Huber | 2016-04-06 | 1 | -6/+4 |
| | | | | MP support was not implemented. | ||||
* | score: Delete Thread_Wait_information::id | Sebastian Huber | 2016-04-06 | 1 | -1/+0 |
| | | | | | | | | | | | This field was only by the monitor in non-multiprocessing configurations. Add new field Thread_Wait_information::remote_id in multiprocessing configurations and use it for the remote procedure call thread queue. Add _Thread_Wait_get_id() to obtain the object identifier for debug and system information tools. Ensure the object layout via static asserts. Add test cases to sptests/spthreadq01. | ||||
* | score: Remove Thread_queue_Queue::operations field | Sebastian Huber | 2016-03-29 | 1 | -2/+5 |
| | | | | | | | | | Remove the Thread_queue_Queue::operations field to reduce the size of this structure. Add a thread queue operations parameter to the _Thread_queue_First(), _Thread_queue_First_locked(), _Thread_queue_Enqueue(), _Thread_queue_Dequeue() and _Thread_queue_Flush() functions. This is a preparation patch to reduce the size of several synchronization objects. | ||||
* | score: Introduce Thread_queue_Queue | Sebastian Huber | 2015-07-23 | 1 | -1/+2 |
| | | | | | | Separate the thread queue heads and lock from the operations. This enables the support for light weight objects which only support one queuing discipline. | ||||
* | score: Delete Thread_queue_Control::timeout_status | Sebastian Huber | 2015-05-19 | 1 | -0/+1 |
| | | | | | Use a parameter for _Thread_queue_Enqueue() instead to reduce memory usage. | ||||
* | score: Add Thread_queue_Control::Lock | Sebastian Huber | 2015-05-19 | 1 | -11/+9 |
| | | | | | | | | | | | Move the complete thread queue enqueue procedure into _Thread_queue_Enqueue_critical(). It is possible to use the thread queue lock to protect state of the object embedding the thread queue. This enables per object fine grained locking in the future. Delete _Thread_queue_Enter_critical_section(). Update #2273. | ||||
* | score: Delete Thread_queue_Control::state | Sebastian Huber | 2015-04-23 | 1 | -0/+2 |
* | score: Delete _CORE_RWLock_Timeout() | Sebastian Huber | 2015-04-22 | 1 | -3/+2 |
| | | | | | This function was identical to _Thread_queue_Timeout(). This makes _Thread_queue_Enqueue_with_handler() obsolete. | ||||
* | score: _Thread_queue_Enqueue_with_handler() | Sebastian Huber | 2013-08-23 | 1 | -0/+1 |
| | | | | | Add thread parameter to _Thread_queue_Enqueue_with_handler() to avoid access to global _Thread_Executing. | ||||
* | score: Create threadq implementation header | Sebastian Huber | 2013-07-26 | 1 | -2/+1 |
| | | | | | | | | Move implementation specific parts of tqdata.h, threadq.h and threadq.inl into new header file threadqimpl.h. The threadq.h contains now only the application visible API. Delete tqdata.h. | ||||
* | score: Create states implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API. | ||||
* | score: Avoid direct usage of _Thread_Executing | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
| | | | | | | Pass the executing thread as a function parameter. Obtain the executing thread inside a thread dispatch critical section to avoid problems on SMP. | ||||
* | score: Create rwlock implementation header | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of corerwlock.h and corerwlock.inl into new header file corerwlockimpl.h. The corerwlock.h contains now only the application visible API. | ||||
* | score misc: Score misc: Clean up Doxygen #11 (GCI 2012) | Daniel Georgiev | 2012-12-01 | 1 | -16/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013204 | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -1/+1 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-04 | 1 | -1/+1 |
* | 2007-11-27 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-11-27 | 1 | -0/+1 |
| | | | | | | | * posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, rtems/include/rtems/rtems/barrier.h, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c: Fixed several implementation errors. | ||||
* | 2006-12-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2006-12-04 | 1 | -1/+1 |
| | | | | | | | | * posix/src/prwlockunlock.c, rtems/Makefile.am, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, score/src/corerwlockobtainread.c, score/src/corerwlockrelease.c: Complete implementation of barrier as the rest of the test code is now implemented. Also add blocking code to rwlock. | ||||
* | 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2006-11-15 | 1 | -1/+5 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h, sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/corerwlock.h, score/include/rtems/score/threadq.h, score/src/corerwlockobtainread.c, score/src/threadqenqueue.c, score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks, and partial implementation of POSIX rwlocks. * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/spinlock.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/spinlock.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/pbarrier.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlock.c, posix/src/prwlockdestroy.c, posix/src/prwlockinit.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspin.c, posix/src/pspindestroy.c, posix/src/pspininit.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files. | ||||
* | * score/Makefile.am, score/preinstall.am, | Joel Sherrill | 2006-09-25 | 1 | -0/+103 |
score/include/rtems/score/coresem.h, score/include/rtems/score/object.h, score/include/rtems/score/states.h, score/inline/rtems/score/coresem.inl: Add SuperCore Barriers, SpinLocks and a partial implementation of RWLocks. * score/include/rtems/score/corebarrier.h, score/include/rtems/score/corerwlock.h, score/include/rtems/score/corespinlock.h, score/inline/rtems/score/corebarrier.inl, score/inline/rtems/score/corerwlock.inl, score/inline/rtems/score/corespinlock.inl, score/macros/rtems/score/corebarrier.inl, score/macros/rtems/score/corerwlock.inl, score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c: New files. |
