Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Pass the executing thread as a function parameter. Obtain the executing
thread inside a thread dispatch critical section to avoid problems on
SMP.
Move implementation specific parts of coremutex.h and coremutex.inl into
new header file coremuteximpl.h. The coremutex.h contains now only the
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
* score/include/rtems/score/coremutex.h,
score/src/coremutexseizeintr.c: Fix conditional code for inlining
_CORE_mutex_Seize_interrupt_trylock() and add comments.
* configure.ac, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/coremutex.inl: Add the ability to disable
inlining coremutex seize. This reduces the code size and also
improves the process of coverage analysis.
* score/src/coremutexseizeintr.c: New file.
