Update #3706
Change the chain order relation to use a directly specified left hand
side value. This is similar to _RBTree_Insert_inline() and helps the
compiler to better optimize the code.
Move message notification to end of critical section and delegate the
message queue release to the notification handler. It may do more
complex notification actions out of the critical section.
Update #2555.
Move common code into _CORE_message_queue_Insert_message().
Remove _CORE_message_queue_Set_message_priority() and set the priority
in _CORE_message_queue_Insert_message().
Aggregate several critical sections into a bigger one. Sending and
receiving messages is now protected by an ISR lock. Thread dispatching
is only disabled in case a blocking operation is necessary. The message
copy procedure is done inside the critical section (interrupts
disabled). Thus this change may have a negative impact on the interrupt
latency in case very large messages are transferred.
Update #2273.
Move the linear search into a critical section to avoid corruption due
to higher priority interrupts. The interrupt disable time depends now
on the count of pending messages.
Close #2328.
application visible API.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Move implementation specific parts of coremsg.h and coremsg.inl into new
header file coremsgimpl.h. The coremsg.h contains now only the
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/schedulerpriorityyield.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
* score/src/coremsginsert.c: Fix typo.
Coverity Id 148/STRAY_SEMICOLON
* score/src/coremsginsert.c: Slightly modify macro.
* score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsginsert.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c: Add wrappers for
accessing message priority. Since these are empty when priority-based
message queues are disabled, this eliminates some of the
conditionals.
* score/include/rtems/score/coremsg.h,
score/src/coremsgsubmit.c, score/src/objectnametoidstring.c: Disable
the Core Message Queue features of notification, priority messages,
and blocking sends when no API requires them.
* score/src/corebarrier.c, score/src/corebarrierrelease.c,
score/src/corebarrierwait.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgflushwait.c, score/src/coremsginsert.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/corerwlock.c, score/src/coresem.c,
score/src/coresemflush.c, score/src/coresemseize.c,
score/src/threadblockingoperationcancel.c,
score/src/threadqenqueue.c: Remove unnecessary include of mpci.h.
PR 820/rtems
score/macros/rtems/score/coremsg.inl, score/src/coremsginsert.c:
Increment of pending message count should be atomic with insertion on
the pending message chain. Determination of the need to call the
notification handler should also be in this atomic section of code.
and _CORE_message_queue_Insert_message for posix message queues.
+ Yellow line tested new source
