Update #3706
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
Move lock acquire to caller of _CORE_message_queue_Close() to allow
state checks during object close operations under lock protection.
Ensures deletion safety on uni-processor configuration.
Replace _Thread_queue_Flush() with _Thread_queue_Flush_critical() and
add a filter function for customization of the thread queue flush
operation.
Update #2555.
Drop status parameter since each caller used
CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED.
Remove superfluous _CORE_message_queue_Flush().
Remove superfluous _CORE_message_queue_Flush() since we completely
re-initialize the structure in _CORE_message_queue_Initialize().
Change _Thread_queue_Flush() into a macro that invokes
_Thread_queue_Do_flush() with the parameter set defined by
RTEMS_MULTIPROCESSING. For multiprocessing configurations add the
object identifier to avoid direct use of the thread wait information.
Use mp_ prefix for multiprocessing related parameters.
Rename Thread_queue_Flush_callout to Thread_queue_MP_callout since this
type will be re-used later for other operations as well.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
Aggregate several critical sections into a bigger one. Sending and
receiving messages is now protected by an ISR lock. Thread dispatching
is only disabled in case a blocking operation is necessary. The message
copy procedure is done inside the critical section (interrupts
disabled). Thus this change may have a negative impact on the interrupt
latency in case very large messages are transferred.
Update #2273.
Check the number of pending messages in _CORE_message_queue_Flush() to
avoid race conditions.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
application visible API.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Move implementation specific parts of coremsg.h and coremsg.inl into new
header file coremsgimpl.h. The coremsg.h contains now only the
* score/src/corebarrier.c, score/src/corebarrierrelease.c,
score/src/corebarrierwait.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgflushwait.c, score/src/coremsginsert.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/corerwlock.c, score/src/coresem.c,
score/src/coresemflush.c, score/src/coresemseize.c,
score/src/threadblockingoperationcancel.c,
score/src/threadqenqueue.c: Remove unnecessary include of mpci.h.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
