path: root/cpukit/score/src/corebarrier.c (unfollow)
2019-04-04doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber1-1/+1
Update #3706
2017-01-31score: Add _Thread_queue_Object_nameSebastian Huber1-1/+1
Add the special thread queue name _Thread_queue_Object_name to mark thread queues embedded in an object with identifier. Using the special thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for this purpose since the thread wait information and thread state are protected by different SMP locks in separate critical sections. Remove STATES_THREAD_QUEUE_WITH_IDENTIFIER. Add and use _Thread_queue_Object_initialize(). Update #2858.
2016-05-26score: Add Status_Control for all APIsSebastian Huber1-11/+0
Unify the status codes of the Classic and POSIX API to use the new enum Status_Control. This eliminates the Thread_Control::Wait::timeout_code field and the timeout parameter of _Thread_queue_Enqueue_critical() and _MPCI_Send_request_packet(). It gets rid of the status code translation tables and instead uses simple bit operations to get the status for a particular API. This enables translation of status code constants at compile time. Add _Thread_Wait_get_status() to avoid direct access of thread internal data structures.
2016-05-25score: Move thread queue MP callout to contextSebastian Huber1-3/+3
Drop the multiprocessing (MP) dependent callout parameter from the thread queue extract, dequeue, flush and unblock methods. Merge this parameter with the lock context into new structure Thread_queue_Context. This helps to gets rid of the conditionally compiled method call helpers.
2016-04-21score: Introduce _Thread_queue_Flush_critical()Sebastian Huber1-1/+11
Replace _Thread_queue_Flush() with _Thread_queue_Flush_critical() and add a filter function for customization of the thread queue flush operation. Update #2555.
2016-03-29score: Remove Thread_queue_Queue::operations fieldSebastian Huber1-4/+1
Remove the Thread_queue_Queue::operations field to reduce the size of this structure. Add a thread queue operations parameter to the _Thread_queue_First(), _Thread_queue_First_locked(), _Thread_queue_Enqueue(), _Thread_queue_Dequeue() and _Thread_queue_Flush() functions. This is a preparation patch to reduce the size of several synchronization objects.
2015-05-19score: Delete Thread_queue_Control::timeout_statusSebastian Huber1-2/+1
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory usage.
2015-04-23score: Delete Thread_queue_Control::stateSebastian Huber1-2/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-07-26score: Create threadq implementation headerSebastian Huber1-2/+1
Move implementation specific parts of tqdata.h, threadq.h and threadq.inl into new header file threadqimpl.h. The threadq.h contains now only the application visible API. Delete tqdata.h.
2013-07-26score: Create states implementation headerSebastian Huber1-2/+1
Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API.
2013-07-22score: Create barrier implementation headerSebastian Huber1-1/+1
Move implementation specific parts of corebarrier.h and corebarrier.inl into new header file corebarrierimpl.h. The corebarrier.h contains now only the application visible API.
2012-11-30score misc: Score misc: Clean up Doxygen #9 (GCI 2012)Alex Ivanov1-19/+7
This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-07-242011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+1
* ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
2008-09-052008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+0
* score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/corerwlock.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemseize.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/threadblockingoperationcancel.c, score/src/threadqenqueue.c: Remove unnecessary include of mpci.h.
2006-09-25 * score/Makefile.am, score/preinstall.am,Joel Sherrill1-0/+60
score/include/rtems/score/coresem.h, score/include/rtems/score/object.h, score/include/rtems/score/states.h, score/inline/rtems/score/coresem.inl: Add SuperCore Barriers, SpinLocks and a partial implementation of RWLocks. * score/include/rtems/score/corebarrier.h, score/include/rtems/score/corerwlock.h, score/include/rtems/score/corespinlock.h, score/inline/rtems/score/corebarrier.inl, score/inline/rtems/score/corerwlock.inl, score/inline/rtems/score/corespinlock.inl, score/macros/rtems/score/corebarrier.inl, score/macros/rtems/score/corerwlock.inl, score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c: New files.
