Pass the executing thread as a function parameter. Obtain the executing
thread inside a thread dispatch critical section to avoid problems on
SMP.
Move implementation specific parts of coremutex.h and coremutex.inl into
new header file coremuteximpl.h. The coremutex.h contains now only the
application visible API.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
PR 1872
* score/src/apimutexlock.c, score/src/apimutexunlock.c: Added smp
support to apimutex.
* score/src/apimutexlock.c, score/src/apimutexunlock.c: Functions were
in opposite files. Whoops!
* sapi/src/exinit.c, score/Makefile.am,
score/include/rtems/score/apimutex.h: API Mutex calls should never
have been inlined. Inlining them lead to many inlined copies of core
mutex lock. This lead to over 2K savings in the SPARC/ERC32
minimum.exe.
* score/src/apimutex.c, score/src/apimutexallocate.c,
score/src/apimutexlock.c, score/src/apimutexunlock.c: New files.
