The previous vprintk() implementation had a questionable licence header,
lacks support for the 'z' and 'j' format specifiers, is not robust
against invalid format specifiers, uses a global variable for output.
Replace it with a stripped down version of the FreeBSD kernel kvprintf()
function.
The new implementation allows a low overhead rtems_snprintf() if
necessary.
Update #3199.
Close #3216.
Use Processor_mask instead.
Update #2514.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Update #3056.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Update #2556.
This makes it possible to add scheduler nodes to structures defined in
<rtems/score/thread.h>.
Update #2556.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Added only for evaluation purposes. We have to compare the performance
against the ticket lock on the interesting platforms via
smptests/smplock01.
The following GCC shortcoming affects the MCS lock:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=66867
Start with a copy of the Priority SMP scheduler implementation.
Update #2510.
Make rtems_initialize_data_structures(),
rtems_initialize_before_drivers() and rtems_initialize_device_drivers()
static. Rename rtems_initialize_start_multitasking() to
rtems_initialize_executive() and call the registered system
initialization handlers in this function. Add system initialization API
available via #include <rtems/sysinit.h>. Update the documentation
accordingly.
This is no functional change, only the method to call the existing
initialization routines changes. Instead of direct function calls a
table of function pointers contained in the new RTEMS system
initialization linker set is used. This table looks like this (the
actual addresses depend on the target).
nm *.exe | grep _Linker | sort
0201a2d0 D _Linker_set__Sysinit_begin
0201a2d0 D _Linker_set__Sysinit_bsp_work_area_initialize
0201a2d4 D _Linker_set__Sysinit_bsp_start
0201a2d8 D _Linker_set__Sysinit_rtems_initialize_data_structures
0201a2dc D _Linker_set__Sysinit_bsp_libc_init
0201a2e0 D _Linker_set__Sysinit_rtems_initialize_before_drivers
0201a2e4 D _Linker_set__Sysinit_bsp_predriver_hook
0201a2e8 D _Linker_set__Sysinit_rtems_initialize_device_drivers
0201a2ec D _Linker_set__Sysinit_bsp_postdriver_hook
0201a2f0 D _Linker_set__Sysinit_end
Add test sptests/spsysinit01.
Update #2408.
Update #2408.
Close #2477.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
New test sptests/timecounter01.
Update #2271.
Use thread wait flags for synchronization. The enqueue operation is now
part of the initial critical section. This is the key change and
enables fine grained locking on SMP for objects using a thread queue
like semaphores and message queues.
Update #2273.
Make <rtems/score/atomic.h> available for all RTEMS configurations. Use
inline functions instead of macros. Use ISR disable/enable on
uni-processor configurations to ensure atomicity.
Update #2273.
not updated.
This scheduler attempts to account for needed thread migrations caused
as a side-effect of a thread state, affinity, or priority change operation.
This scheduler has its own allocate_processor handler named
_Scheduler_SMP_Allocate_processor_exact() because
_Scheduler_SMP_Allocate_processor() attempts to prevent an executing
thread from moving off its current CPU without considering affinity.
Without this, the scheduler makes all the right decisions and then
they are discarded at the end.
==Side Effects of Adding This Scheduler==
Added Thread_Control * parameter to Scheduler_SMP_Get_highest_ready type
so methods looking for the highest ready thread can filter by the processor
on which the thread blocking resides. This allows affinity to be considered.
Simple Priority SMP and Priority SMP ignore this parameter.
+ Added get_lowest_scheduled argument to _Scheduler_SMP_Enqueue_ordered().
+ Added allocate_processor argument to the following methods:
- _Scheduler_SMP_Block()
- _Scheduler_SMP_Enqueue_scheduled_ordered()
+ schedulerprioritysmpimpl.h is a new file with prototypes for methods
which were formerly static in schedulerprioritysmp.c but now need to
be public to be shared with this scheduler.
NOTE:
_Scheduler_SMP_Get_lowest_ready() appears to have a path which would
allow it to return a NULL. Previously, _Scheduler_SMP_Enqueue_ordered()
would have asserted on it. If it cannot return a NULL,
_Scheduler_SMP_Get_lowest_ready() should have an assertions.
A resource is something that has at most one owner at a time and may
have multiple rivals in case an owner is present. The owner and rivals
are impersonated via resource nodes. A resource is represented via the
resource control structure. The resource controls and nodes are
organized as trees. It is possible to detect deadlocks via such a
resource tree. The _Resource_Iterate() function can be used to iterate
through such a resource tree starting at a top node.
Add basic support for the Multiprocessor Resource Sharing Protocol
(MrsP).
The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A.
Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor
Resource Sharing Protocol - MrsP, Proceedings of the 25th Euromicro
Conference on Real-Time Systems (ECRTS 2013), July 2013. It is a
generalization of the Priority Ceiling Protocol to SMP systems. Each
MrsP semaphore uses a ceiling priority per scheduler instance. These
ceiling priorities can be specified with rtems_semaphore_set_priority().
A task obtaining or owning a MrsP semaphore will execute with the
ceiling priority for its scheduler instance as specified by the MrsP
semaphore object. Tasks waiting to get ownership of a MrsP semaphore
will not relinquish the processor voluntarily. In case the owner of a
MrsP semaphore gets preempted it can ask all tasks waiting for this
semaphore to help out and temporarily borrow the right to execute on one
of their assigned processors.
The help out feature is not implemented with this patch.
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
Add per-CPU profiling stats API. Implement the thread dispatch disable
level profiling. The interrupt profiling must be implemented in CPU
port specific parts (mostly assembler code). Add a support function
_Profiling_Outer_most_interrupt_entry_and_exit() for this purpose.
This new Score Handler provides a structure to manage a
cpu_set_t plus helper routines to validate the contents
against the current system configuration.
Rename rtems_smp_process_interrupt() into
_SMP_Inter_processor_interrupt_handler(). Delete unused header file
<rtems/bspsmp.h>.
Collect SMP implementation specific parts in the
<rtems/score/smpimpl.h> header file.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Replace Scheduler_simple_smp_Control with Scheduler_SMP_Control. Rename
_Scheduler_simple_smp_Instance() to _Scheduler_SMP_Instance().
Add call to _Scheduler_Schedule() in missing path after
_Thread_Set_transient() in _Thread_Change_priority(). See also
sptests/spintrcritical19.
Add thread parameter to _Scheduler_Schedule(). This parameter is
currently unused but may be used in future SMP schedulers.
Do heir selection in _Scheduler_Schedule(). Use
_Scheduler_Update_heir() for this in the particular scheduler
implementation.
Add and use _Scheduler_Generic_block().
Move the nanoseconds since last tick support from the Watchdog to the
TOD handler. Now the TOD managment is encapsulated in the TOD_Control
structure.
ISR locks are low-level locks to protect critical sections accessed by
threads and interrupt service routines.
On single processor configurations the ISR locks degrade to simple ISR
disable/enable sequences. No additional storage or objects are
required.
This synchronization primitive is supported on SMP configurations. Here
SMP locks are used.
TOD_MILLISECONDS_TO_TICKS().
application visible API.
