path: root/cpukit/score/macros/rtems (follow)
* made initialization routine a regular subroutineJoel Sherrill1996-04-221-41/+0
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-061-2/+2
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* Removed the internal thread objects and dispersed its contents toJoel Sherrill1996-02-211-0/+16
| | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized.
* changed post task extension from user set to api set and added flagJoel Sherrill1996-02-131-9/+0
| | | | in each thread which must be set when the post switch extension is to be run.
* new isr synchronization algorithm using a single enumerated set of states.Joel Sherrill1996-02-091-1/+0
* alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENTJoel Sherrill1996-02-081-1/+1
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-203-15/+23
| | | | partially recovered working tree, etc
* SPARC port passes all testsJoel Sherrill1995-10-302-6/+28
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-2/+2
* Fixed typoJoel Sherrill1995-09-271-2/+2
* posix support initially addedJoel Sherrill1995-09-265-3/+34
* Modifications from Tony Bennett accepted to return aligned block.Joel Sherrill1995-09-191-0/+12
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-0/+121
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1114-117/+199
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-282-1/+10
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-26/+7
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-226-6/+6
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* + Added object type field to object id.Joel Sherrill1995-08-181-4/+17
| | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control.
* bug fixes to make macro implementations workJoel Sherrill1995-08-166-34/+11
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-27/+0
* Initial revisionJoel Sherrill1995-05-1119-0/+2030
