path: root/cpukit/score/macros/rtems/score/wkspace.inl (follow)
* made initialization routine a regular subroutineJoel Sherrill1996-04-221-41/+0
* alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENTJoel Sherrill1996-02-081-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-9/+12
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-221-1/+1
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* bug fixes to make macro implementations workJoel Sherrill1995-08-161-25/+1
* Initial revisionJoel Sherrill1995-05-111-0/+101
