path: root/cpukit/score/macros/rtems/score/tqdata.inl (follow)
* removed Thread_queue_Get_number_waitingMark Johannes1996-08-131-9/+0
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-061-2/+2
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* new isr synchronization algorithm using a single enumerated set of states.Joel Sherrill1996-02-091-1/+0
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-0/+12
| | | | partially recovered working tree, etc
* posix support initially addedJoel Sherrill1995-09-261-0/+9
* Initial revisionJoel Sherrill1995-05-111-0/+39
