Move implementation specific parts of schedulersimple.h and
schedulersimple.inl into new header file schedulersimpleimpl.h. The
schedulersimple.h contains now only the application visible API.
Move implementation specific parts of stack.h and stack.inl into new
header file stackimpl.h. The stack.h contains now only the application
visible API.
Move implementation specific parts of heap.h and heap.inl into new
header file heapimpl.h. The heap.h contains now only the application
visible API.
Move implementation specific parts of rbtree.h and rbtree.inl into new
header file rbtreeimpl.h. The rbtree.h contains now only the
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
Move implementation specific parts of chain.h and chain.inl into new
header file chainimpl.h. The chain.h contains now only the application
visible API.
Move implementation specific parts of corespinlock.h and
corespinlock.inl into new header file corespinlockimpl.h. The
corespinlock.h contains now only the application visible API.
Move implementation specific parts of corerwlock.h and corerwlock.inl
into new header file corerwlockimpl.h. The corerwlock.h contains now
Move implementation specific parts of corebarrier.h and corebarrier.inl
into new header file corebarrierimpl.h. The corebarrier.h contains now
Move implementation specific parts of coremsg.h and coremsg.inl into new
header file coremsgimpl.h. The coremsg.h contains now only the
Move implementation specific parts of coresem.h and coresem.inl into new
header file coresemimpl.h. The coresem.h contains now only the
Delete now unused file <rtems/score/isr.inl>.
Move implementation specific parts of coremutex.h and coremutex.inl into
new header file coremuteximpl.h. The coremutex.h contains now only the
Delete _Thread_libc_reent and add __getreent() instead according to
__DYNAMIC_REENT__ define.
For SMP configurations __DYNAMIC_REENT__ must be defined.
A Newlib including the following patch is required:
2013-07-09 Sebastian Huber <sebastian.huber@embedded-brains.de>
* libc/include/sys/config.h (__DYNAMIC_REENT__): Define for RTEMS.
Add and use _Scheduler_simple_Insert_priority_fifo_order(),
_Scheduler_simple_Insert_priority_lifo_order(),
_Scheduler_simple_Insert_priority_fifo() and
_Scheduler_simple_Insert_priority_lifo().
The yielding thread of the yield operation is now specified by a
parameter. The tick operation may be performed for each executing
thread in a SMP configuration.
Add and use _Scheduler_Start_idle().
Delete _Thread_Evaluate_is_dispatch_needed().
Use _Thread_Dispatch_is_enabled() in rtems_task_mode() instead of the
system state to determine if a thread dispatch is allowed. Signales are
now delivered in rtems_task_mode() even if preemption is disabled. This
is in line with rtems_signal_send().
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
Provide SMP support. The ISR disable/enable is not enough to ensure
mutual exclusion for SMP configurations.
Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
This field is unused except for special case simulator clock drivers.
In these places use an alternative. Add and use
_Thread_Set_global_exit_status() and _Thread_Get_global_exit_status().
This is the result of a sed script which converts all uses
of @{ into a consistent form.
http://www.google-melange.com/gci/task/view/google/gci2012/8137204
This function is to big to inline. It leads also to test case
explosion.
The function _RBTree_Has_only_one_node shall return a boolean value, but
returns NULL. NULL, however, is defined as: (void *)0. Hence it does not match
the scalar bool type. Return false instead.
Delete _TOD_Get_as_timestamp().
System events are similar to normal events. They offer a second set of
events. These events are intended for internal RTEMS use and should not
be used by applications (with the exception of the transient system
event).
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
In particular CPU_INTERRUPT_NUMBER_OF_VECTORS and
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER are only used on
Simple Vectored Architectures, so do not depend on
them being defined. This disables as much as possible
that is specific to the Simple Vectored Model and
not expected to be used on architectures which use
the Programmable Interrupt Controller model for
interrupt handler vectoring.
