are automatically activated upon insertion.
WATCHDOG_BEING_INSERTED.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ variable length messages
+ named devices
+ debug monitor
blocking mechanism for it.
