* include/rtems/score/object.h, inline/rtems/score/object.inl,
src/objectcomparenamestring.c: Address PR81 that
reworked POSIX message queues to add a descriptor separate from
the underlying message queue. This allows non-blocking to follow
the "open" not the underlying queue. As part of debugging this
it became clear that _Objects_Compare_name_string was broken
and a simple version using strncmp() was substituted.
* include/rtems/system.h: Remove targopts.h.
* include/rtems/system.h: Add the sparc to the target supporting
multlibs.
* include/rtems/system.h: Add i386 to multilib-able targets.
* Per PR142, make task switch extension its own list.
* include/rtems/score/userext.h: Reflect above by adding
User_extensions_Switch_control and adding it to User_extenions_Control.
* inline/rtems/score/userext.inl: Allocate all memory in one chunk
to minimize overhead. Address processing dedicated switch chain.
* cpu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rtems/score/watchdog.h: Added WATCHDOG_MAXIMUM_INTERVAL.
* include/rtems/system.h: Fix typo in yesterday's change:
RTEMS_MULTILIBS.
* include/rtems/system.h: Only include cpuopts.h when building a
multilib configuration. Some ports still need targopts.h but this
small modification lets those ports work non-multilib while
fixing being fixed for multilib.
* include/rtems/seterr.h: Add do {..} while (0) in defines.
Rename set_errno_and_return_minus_one into
rtems_set_errno_and_return_minus_one.
This was tracked as PR91.
* include/rtems/score/isr.h, inline/rtems/score/isr.inl,
macros/rtems/score/isr.inl: Modified to allow any port to provide
its own implementation of the macro _ISR_Is_in_progress. If the
port overrides this macro, it must provide a non-inlined function
implementation.
Reported by Todor.Todorov@barco.com and tracked as PR36.
* include/rtems/score/object.h: Added prototype for
_Objects_Get_by_index().
* src/objectget.c, src/objectgetisr.c: Corrected procedure for
getting index from Id so it is correct and optimal for both single
and multiprocessor configurations.
* include/Makefile.am: Fixed path to cpuopts-tmp.h.
* macros/rtems/score/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs, require automake-1.5.
* inline/rtems/score/Makefile.am: Remove.
* Makefile.am: require automake-1.5
* include/rtems/score/coremsg.h, src/coremsgsubmit.c: Add a new
return status to account for blocking sends. Otherwise, the
caller will think that the returned message status will have
the ultimate results of the operation. If the send times out,
the final status will be in the return_code of the thread.
* include/rtems/score/coremsg.h, inline/rtems/score/coremsg.inl,
src/coremsgsubmit.c: Unblocking message queue operations should
by Suvrat Gupta <suvrat@utstar.com>.
* include/rtems/score/.cvsignore: Add stamp-h, cpuopts.h,
cpuopts.h.in, cpuopts-tmp.h.
* include/rtems/score/isr.h, src/isr.c: Allocate it from the
workspace rather than explicitly declaring it. This allows
the size to be a non-constant from the perspective of score/cpu.
* include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API)
so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(),
POSIX_BOTTOM_REACHED() are actually included.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* src/heapgetinfo.c, include/rtems/score/heap.h, src/Makefile.am:
Added _Heap_Get_information() and information control block.
* src/heapgetinfo.c: New file.
* rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not
targopts.h to reduce dependency on BSP.
all APIs.
* include/rtems/system.h: Include cpuopts.h for __i386__.
is available.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
using cpuopts.h and not targopts.h.
that addresses aspects of the targopts.h multilib related
issues.
* Move targopts.h to libbsp/include, because the current targopts.h
actually is a per-BSP-header and therefore can not stay below exec/.
* Introduce an autoheader generated header file
(exec/score/include/rtems/score/cpuopts.h), which shall take per-cpu
configuration options only.
* Move all autoconf-detectable/configure specified per-cpu
option-defines from targopts.h to cpuopts.h.
* Add Makefiles to the libbsp/shared directory hierarchy.
* The new per-bsp targopts.h in libbsp includes the per-cpu
cpuopts.h. This way, the new targopts.h is kept backward compatible
to the old targopts.h and existing BSPs which (carelessly) include
targopts.h (i386, ppc) should be kept working when using the
multilib-disabled configuration scheme.
* cpuopts.h is not yet complete, because the per-BSP make-targopts
rules from custom/<BSP>.cfg files can not be applied to files below
exec/ when building multilibs.
* All files below exec/ should not include targopts.h anymore, but
should include cpuopts.h instead. However, eliminating inclusion of
targopts.h currently triggers further structural / header file inclusion
related issues, because several ports apply BSP or CPU_MODEL specific
defines from targopts.h below exec/
static inline routine _CORE_mutex_Seize_interrupt_trylock since
static routines are not included when in an application.
if the mutex is successfully obtained.
significant things:
and PowerPC
same code base.
I'd like to propose a change to RTEMS task variables that I think would
make them more useful. I think that it is early enough in their
existence to still make changes to their API.
1) Change type from `int' to `void *'.
2) Add extra argument to task_variable_add -- if non-NULL, a pointer to
a `destructor' function to be called when the task exits. This function
would be called with that task's value of the task variable as its
argument. In many cases, the `dtor' function could be `free'.
rtems_status_code rtems_task_variable_add (
rtems_id tid, void **ptr, void (*dtor)(void *));
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr);
This would be all we'd need to cleanly and efficiently support C++
per-thread exception information without dragging in all that POSIX API
stuff.
were done by Joel.
+ Changed priority to be based off of min and max int.
RTEMS API extension to avoid problems when the extension is freed.
Eventually the task variable switch extension should become part
of the core context switch and the Ada tcb self implemented in
terms of it.
for RTEMS.
