path: root/cpukit/score/include (unfollow)
2018-01-25Remove make preinstallChris Johns109-31411/+0
2017-12-06libio: Use API mutexSebastian Huber1-1/+1
2017-12-04score: Use self-contained API mutexSebastian Huber5-75/+23
Use a self-contained recursive mutex for API_Mutex_Control. The API mutexes are protected against asynchronous thread cancellation. Add dedicated mutexes for libatomic and TOD. Close #2629. Close #2630.
2017-11-22sapi: New implementation of rtems_panic()Sebastian Huber1-0/+7
The previous rtems_panic() implementation was quite heavy weight. It depended on _exit() which calls the global destructors. It used fprintf(stderr, ...) for output which depends on an initialized console device and the complex fprintf(). Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic() and output via vprintk(). Update #3244.
2017-11-22INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULLSebastian Huber1-1/+1
Delete superfluous INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL. Update #3243.
2017-11-22score: Simplify global constructionSebastian Huber1-13/+10
Update #3243.
2017-11-20score: Optimize scheduler priority updatesSebastian Huber10-236/+208
Thread priority changes may append or prepend the thread to its priority group on the scheduler ready queue. Previously, a separate priority value and a prepend-it flag in the scheduler node were used to propagate a priority change to the scheduler. Now, use an append-it bit in the priority control and reduce the plain priority value to 63 bits. This change leads to a significant code size reduction (about 25%) of the SMP schedulers. The negligible increase of the standard priority scheduler is due to some additional shift operations (SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()). Before: text filename 136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o 464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o 24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o 108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o 292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o 264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o text filename 280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o 488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o 164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o 328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o text filename 24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o After: text filename 136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o 272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o 24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o 108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o 292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o 264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o text filename 280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o 488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o 208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o 164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o 332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o text filename 18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
2017-11-17cpukit: Add _arc4random_getentropy_fail.Christian Mauderer1-1/+2
Add a default implementation of _arc4random_getentropy_fail with an internal error. Update #3239.
2017-11-17score: Adjust _Scheduler_EDF_SMP_Insert_ready()Sebastian Huber1-1/+1
Use only one parameter to compute the next generation. Use index 0 for LIFO ordering, and index 1 for FIFO ordering.
2017-11-09score: Change _Timecounter_Time_uptime to int32_tSebastian Huber1-1/+2
Move basic timecounter API shared with BSD network stack to <machine/_timecounter.h>. Update #3185.
2017-11-09posix: Change created_with_explicit_schedulerSebastian Huber1-0/+6
Remove POSIX_API_Control::created_with_explicit_scheduler. Add Thread_Control::was_created_with_inherited_scheduler. This fixes also pthread_getattr_np() for Classic tasks. Update #2514.
2017-11-06score: Use Processor_mask instead of cpu_set_tSebastian Huber1-2/+2
2017-11-06score: _Chain_Insert_ordered_unprotected()Sebastian Huber4-46/+89
Change the chain order relation to use a directly specified left hand side value. This is similar to _RBTree_Insert_inline() and helps the compiler to better optimize the code.
2017-11-06score: Remove superfluous includeSebastian Huber1-3/+0
Update #3059.
2017-11-06score: Add _IO_Printf() and _IO_Vprintf()Sebastian Huber1-0/+46
The previous vprintk() implementation had a questionable licence header, lacks support for the 'z' and 'j' format specifiers, is not robust against invalid format specifiers, uses a global variable for output. Replace it with a stripped down version of the FreeBSD kernel kvprintf() function. The new implementation allows a low overhead rtems_snprintf() if necessary. Update #3199. Close #3216.
2017-11-02posix: Use far future for very long timeoutsSebastian Huber1-0/+30
Close #3205.
2017-10-28score: Simplify SMP get lowest scheduledSebastian Huber1-7/+4
There is no need to pass in the order relation since the scheduled threads reside on an already ordered chain. The caller will decide what to do with the lowest scheduled thread.
2017-10-26score: Delete _Scheduler_Thread_set_priority()Sebastian Huber1-12/+0
2017-10-24score: Move thread queue timeout handlingSebastian Huber6-106/+114
Update #3117. Update #3182.
2017-10-24score: Rename function threadq support functionSebastian Huber3-7/+7
Rename _Thread_queue_Context_set_do_nothing_enqueue_callout() into _Thread_queue_Context_set_enqueue_do_nothing_extra(). More _Thread_queue_Context_set_enqueue_*() functions will follow. Update #3117. Update #3182.
2017-10-24score: Add _Thread_Continue()Sebastian Huber1-2/+16
2017-10-24score: _Watchdog_Per_CPU_lazy_insert_monotonic()Sebastian Huber1-0/+25
2017-10-24score: Add _Watchdog_Monotonic_from_timespec()Sebastian Huber1-0/+16
2017-10-24score: Add _Watchdog_Nanoseconds_per_tickSebastian Huber1-0/+8
Move it from the configuration to a separate variable. Update #3117. Update #3182.
2017-10-24score: _Watchdog_Is_far_future_monotonic_timespecSebastian Huber2-0/+16
2017-10-24score: Add _Watchdog_Is_valid_interval_timespec()Sebastian Huber1-0/+7
2017-10-24score: _Watchdog_Is_far_future_realtime_timespec()Sebastian Huber1-9/+32
2017-10-24score: Rename _Watchdog_Ticks_from_*()Sebastian Huber1-3/+3
Rename _Watchdog_Ticks_from_*() to _Watchdog_Realtime_from_*(). This highlights that these routines are used for the CLOCK_REALTIME watchdogs (in contrast to CLOCK_MONOTONIC). Update #3117. Update #3182.
2017-10-24score: Add _Watchdog_Ticks_per_secondSebastian Huber1-0/+8
This value is frequently used. Avoid the function call overhead and the integer division at run-time. Update #3117. Update #3182.
2017-10-24score: Add _Thread_Add_timeout_ticks()Sebastian Huber1-6/+5
Replace _Thread_Timer_insert_monotonic() with _Thread_Add_timeout_ticks(). Update #3117. Update #3182.
2017-10-17score: Rename _Watchdog_Per_CPU_insert_monotonic()Sebastian Huber2-2/+2
Rename _Watchdog_Per_CPU_insert_monotonic() in _Watchdog_Per_CPU_insert_ticks(). Update #3117. Update #3182.
2017-10-17score: Rename watchdog variantsSebastian Huber3-26/+30
Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to highlight the corresponding POSIX CLOCK_MONOTONIC. Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to highlight the corresponding POSIX CLOCK_REALTIME. Update #3117. Update #3182.
2017-10-12score: Remove unused function declarationSebastian Huber1-15/+0
2017-10-12timecounter: Update FreeBSD identifiersSebastian Huber4-4/+4
Update #3175.
2017-10-12timecounter: Merge FreeBSD change r304285Konstantin Belousov1-0/+14
Implement userspace gettimeofday(2) with HPET timecounter. Right now, userspace (fast) gettimeofday(2) on x86 only works for RDTSC. For older machines, like Core2, where RDTSC is not C2/C3 invariant, and which fall to HPET hardware, this means that the call has both the penalty of the syscall and of the uncached hw behind the QPI or PCIe connection to the sought bridge. Nothing can me done against the access latency, but the syscall overhead can be removed. System already provides mappable /dev/hpetX devices, which gives straight access to the HPET registers page. Add yet another algorithm to the x86 'vdso' timehands. Libc is updated to handle both RDTSC and HPET. For HPET, the index of the hpet device to mmap is passed from kernel to userspace, index might be changed and libc invalidates its mapping as needed. Remove cpu_fill_vdso_timehands() KPI, instead require that timecounters which can be used from userspace, to provide tc_fill_vdso_timehands{,32}() methods. Merge i386 and amd64 libc/<arch>/sys/__vdso_gettc.c into one source file in the new libc/x86/sys location. __vdso_gettc() internal interface is changed to move timecounter algorithm detection into the MD code. Measurements show that RDTSC even with the syscall overhead is faster than userspace HPET access. But still, userspace HPET is three-four times faster than syscall HPET on several Core2 and SandyBridge machines. Tested by: Howard Su <howard0su@gmail.com> Sponsored by: The FreeBSD Foundation MFC after: 1 month Differential revision: https://reviews.freebsd.org/D7473 Update #3175.
2017-10-12timecounter: Merge FreeBSD change r303382Konstantin Belousov1-7/+14
Hide the boottime and bootimebin globals, provide the getboottime(9) and getboottimebin(9) KPI. Change consumers of boottime to use the KPI. The variables were renamed to avoid shadowing issues with local variables of the same name. Issue is that boottime* should be adjusted from tc_windup(), which requires them to be members of the timehands structure. As a preparation, this commit only introduces the interface. Some uses of boottime were found doubtful, e.g. NLM uses boottime to identify the system boot instance. Arguably the identity should not change on the leap second adjustment, but the commit is about the timekeeping code and the consumers were kept bug-to-bug compatible. Tested by: pho (as part of the bigger patch) Reviewed by: jhb (same) Discussed with: bde Sponsored by: The FreeBSD Foundation MFC after: 1 month X-Differential revision: https://reviews.freebsd.org/D7302 Update #3175.
2017-10-12timecounter: Merge FreeBSD change r298981Pedro Giffuni1-1/+1
sys/sys: minor spelling fixes. While the changes are minor, these headers are very visible. MFC after: 2 weeks Update #3175.
2017-10-12timecounter: Merge FreeBSD change r304285Ian Lepore1-1/+1
Constify the pointers to eventtimer and timecounter name strings. The need for this appears as soon as you try to set the names to something that isn't a "quoted literal". (I'm actually confused why quoted strings aren't a problem as well, we must have some warning disabled.) Update #3175.
2017-10-12timecounter: Merge FreeBSD change r282424Ian Lepore1-3/+15
Implement a mechanism for making changes in the kernel<->driver PPS interface without breaking ABI or API compatibility with existing drivers. The existing data structures used to communicate between the kernel and driver portions of PPS processing contain no spare/padding fields and no flags field or other straightforward mechanism for communicating changes in the structures or behaviors of the code. This makes it difficult to MFC new features added to the PPS facility. ABI compatibility is important; out-of-tree drivers in module form are known to exist. (Note that the existing api_version field in the pps_params structure must contain the value mandated by RFC 2783 and any RFCs that come along after.) These changes introduce a pair of abi-version fields which are filled in by the driver and the kernel respectively to indicate the interface version. The driver sets its version field before calling the new pps_init_abi() function. That lets the kernel know how much of the pps_state structure is understood by the driver and it can avoid using newer fields at the end of the structure that it knows about if the driver is a lower version. The kernel fills in its version field during the init call, letting the driver know what features and data the kernel supports. To implement the new version information in a way that is backwards compatible with code from before these changes, the high bit of the lightly-used 'kcmode' field is repurposed as a flag bit that indicates the driver is aware of the abi versioning scheme. Basically if this bit is clear that indicates a "version 0" driver and if it is set the driver_abi field indicates the version. These changes also move the recently-added 'mtx' field of pps_state from the middle to the end of the structure, and make the kernel code that uses this field conditional on the driver being abi version 1 or higher. It changes the only driver currently supplying the mtx field, usb_serial, to use pps_init_abi(). Reviewed by: hselasky@ Update #3175.
2017-10-12timecounter: Merge FreeBSD change r279728Hans Petter Selasky1-0/+5
Add mutex support to the pps_ioctl() API in the kernel. Bump kernel version to reflect structure change. PR: 196897 MFC after: 1 week Update #3175.
2017-10-11score: Remove CPU_set_ControlSebastian Huber5-196/+3
Use Processor_mask instead. Update #2514.
2017-10-10score: Add _Thread_queue_Dispatch_disable()Sebastian Huber3-6/+12
2017-10-09score: Change Timestamp_Control to sbintime_tSebastian Huber3-34/+24
The timestamp are based on the uptime. There is no need for a 64-bit seconds part. The signed 32-bit seconds part of the sbintime_t limits the uptime to roughly 68 years. Close #2740.
2017-10-09score: Use struct timespec for TODSebastian Huber1-46/+8
Use the timestamps only for uptime based values. Use struct timespec for the absolute time values (TOD). Update #2740.
2017-10-09score: Simplify _Timestamp_Add_to()Sebastian Huber1-7/+1
Update #2740.
2017-10-05posix: Implement self-contained POSIX mutexSebastian Huber3-2/+37
POSIX mutexes are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3112.
2017-10-05posix: Implement self-contained POSIX condvarSebastian Huber2-2/+0
POSIX condition variables are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3113.
2017-10-05posix: Implement self-contained POSIX rwlocksSebastian Huber4-91/+56
POSIX rwlocks are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3115.
2017-10-05posix: Implement self-contained POSIX barriersSebastian Huber2-2/+0
POSIX barriers are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3114.
2017-10-05posix: Implement self-contained POSIX semaphoresSebastian Huber1-0/+73
For semaphore object pointer and object validation see POSIX_SEMAPHORE_VALIDATE_OBJECT(). Destruction or close of a busy semaphore returns an error status. The object is not flushed. POSIX semaphores are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3116.
