path: root/cpukit/score/include/sys (follow)
* timecounter: Merge FreeBSD change r282424Ian Lepore2017-10-121-3/+15
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Implement a mechanism for making changes in the kernel<->driver PPS interface without breaking ABI or API compatibility with existing drivers. The existing data structures used to communicate between the kernel and driver portions of PPS processing contain no spare/padding fields and no flags field or other straightforward mechanism for communicating changes in the structures or behaviors of the code. This makes it difficult to MFC new features added to the PPS facility. ABI compatibility is important; out-of-tree drivers in module form are known to exist. (Note that the existing api_version field in the pps_params structure must contain the value mandated by RFC 2783 and any RFCs that come along after.) These changes introduce a pair of abi-version fields which are filled in by the driver and the kernel respectively to indicate the interface version. The driver sets its version field before calling the new pps_init_abi() function. That lets the kernel know how much of the pps_state structure is understood by the driver and it can avoid using newer fields at the end of the structure that it knows about if the driver is a lower version. The kernel fills in its version field during the init call, letting the driver know what features and data the kernel supports. To implement the new version information in a way that is backwards compatible with code from before these changes, the high bit of the lightly-used 'kcmode' field is repurposed as a flag bit that indicates the driver is aware of the abi versioning scheme. Basically if this bit is clear that indicates a "version 0" driver and if it is set the driver_abi field indicates the version. These changes also move the recently-added 'mtx' field of pps_state from the middle to the end of the structure, and make the kernel code that uses this field conditional on the driver being abi version 1 or higher. It changes the only driver currently supplying the mtx field, usb_serial, to use pps_init_abi(). Reviewed by: hselasky@ Update #3175.
* timecounter: Merge FreeBSD change r279728Hans Petter Selasky2017-10-121-0/+5
| | | | | | | | | Add mutex support to the pps_ioctl() API in the kernel. Bump kernel version to reflect structure change. PR: 196897 MFC after: 1 week Update #3175.
* timecounter: Port to RTEMSAlexander Krutwig2015-05-202-0/+4
| | | | | | New test sptests/timecounter01. Update #2271.
* timecounter: Use uint32_t instead of u_intAlexander Krutwig2015-05-191-2/+2
| | | | | | | FreeBSD assumes that u_int is a 32-bit integer type. This is wrong for some 16-bit targets supported by RTEMS. Update #2271.
* timecounter: Import from FreeBSDAlexander Krutwig2015-05-195-0/+940
Update #2271.
